跳转到主内容
Samsung 500C ChromeBook WIreless Card Replacement
你所需要的
  1. Samsung 500C ChromeBook WIreless Card Replacement, Wireless Card: 步骤 1 中的图像 1,2 Samsung 500C ChromeBook WIreless Card Replacement, Wireless Card: 步骤 1 中的图像 2,2
    • Remove the back panel of the device by taking out the seven screws on the back panel of the device.
    • Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
  2. Samsung 500C ChromeBook WIreless Card Replacement: 步骤 2 中的图像 1,3 Samsung 500C ChromeBook WIreless Card Replacement: 步骤 2 中的图像 2,3 Samsung 500C ChromeBook WIreless Card Replacement: 步骤 2 中的图像 3,3
    • Locate the wireless card. It is shown highlighted in picture one.
    • Detach the black and white cords connected to the wireless card and unscrew the screw holding in the card. They are shown highlighted in picture two.
    • Pull the card out of its slot and insert the new card. Reattach the wires and reassemble the device. Note: the white wire connects to the terminal closer to the screw and the black to the other terminal.
结论
团队
Michigan Tech, Team 1-2, Lauer Spring 2014 Michigan Tech, Team 1-2, Lauer Spring 2014 的会员
MTU-LAUER-S14S1G2
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,835
