跳转到主内容
配件
没有特定配件。
  1. Remove the back panel of the device by taking out the seven screws on the back panel of the device. Four of the screws are under the rubber feet so they will need to be removed.  To remove the feet, pry them off with the spudger.
    • Remove the back panel of the device by taking out the seven screws on the back panel of the device.
    • Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
  2. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  3. Remove the seven screws that are holding in the battery.  They can be seen circled in the picture. When unscrewed, lift the battery.  There will be a cable connected to the battery.  Detach this cable from the board and remove the battery. Attach the replacement battery cable to the board and reassemble.  It can be seen highlighted in picture 2.
    • Remove the seven screws that are holding in the battery. They can be seen circled in the picture.
    • When unscrewed, lift the battery. There will be a cable connected to the battery. Detach this cable from the board and remove the battery.
    • Attach the replacement battery cable to the board and reassemble. It can be seen highlighted in picture 2.
    • *Note: When reinserting the battery it is easier to put in the long end first and then dropping the other side in.
结论
3等其他人完成本指南。
Garrett Kissinger
于2014年02月24日注册
692 信誉积分
创作了5篇指南
团队
Michigan Tech, Team 1-2, Lauer Spring 2014 Michigan Tech, Team 1-2, Lauer Spring 2014 的会员
MTU-LAUER-S14S1G2
3 名成员
创作了5篇指南
Samsung 500C ChromeBook Battery where to buy?
Uzi Naveh - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 5
过去的30天: 20
总计 2,268
