跳转到主内容
Samsung 351U Keyboard Key Replacement
你所需要的
  1. Samsung 351U Keyboard Key Replacement, Keyboard Key: 步骤 1 中的图像 1,1
    • Select the key you would like to remove then slide the plastic opening tool beneath it until you hear a pop.
  2. Samsung 351U Keyboard Key Replacement: 步骤 2 中的图像 1,1
    • The key is now out and ready to be removed/replaced.
    • Be sure to only remove one key at a time so they will be in the same place as they were.
    • Clean the key and replace it into the same spot until another pop is heard.
结论
Melvin Nelson
于02/15/17注册
326 声望
创作了3篇指南
团队
USF Tampa, Team 12-4, Eyestone Spring 2017 USF Tampa, Team 12-4, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S12G4
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 666
