简介
The HDMI Port allows for an external source to display an image onto the monitor by using an HDMI cable. If the HDMI Port is damaged, an image might not display onto the monitor.
你所需要的
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
Remove the navigation button connector by pulling while holding down its thumb tab.
To reassemble your device, follow these instructions in reverse order. The process of soldering the components back onto the board is similar to desoldering, the difference is that instead of using the Solder Wick, to suck up the solder, you're using Solder Wire to add solder.
另外一个人完成了本指南。
