跳转到主内容
Samsung 27E510C NAV Button Replacement
你所需要的
  1. Samsung 27E510C  NAV Button Replacement, Back Panel: 步骤 1 中的图像 1,3 Samsung 27E510C  NAV Button Replacement, Back Panel: 步骤 1 中的图像 2,3 Samsung 27E510C  NAV Button Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C  NAV Button Replacement: 步骤 2 中的图像 1,2 Samsung 27E510C  NAV Button Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    Heavy-Duty Spudger
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C  NAV Button Replacement, Rear navigation button: 步骤 3 中的图像 1,1
    • Carefully remove the tape holding down the connector wire.
    • You will need to re-attach the tape upon reassembly.
  4. Samsung 27E510C  NAV Button Replacement: 步骤 4 中的图像 1,1
    • Disconnect the navigation button from the motherboard by holding down the thumb tab and pulling its connector out.
  5. Samsung 27E510C  NAV Button Replacement: 步骤 5 中的图像 1,2 Samsung 27E510C  NAV Button Replacement: 步骤 5 中的图像 2,2
    • Remove the navigation buttons connector wire from the monitors body tab.
  6. Samsung 27E510C  NAV Button Replacement: 步骤 6 中的图像 1,1
    • With one thumb, hold down the tab on the bottom of the navigation buttons base.
    • While holding the tab down, lift the base of the navigation button with your other hand.
  7. Samsung 27E510C  NAV Button Replacement: 步骤 7 中的图像 1,3 Samsung 27E510C  NAV Button Replacement: 步骤 7 中的图像 2,3 Samsung 27E510C  NAV Button Replacement: 步骤 7 中的图像 3,3
    • Remove the connector wire from the defective navigation button by first gripping its connectors thumb tab.
    • While gripping the thumb tab, pull the connector from the base of the navigation button.
    • You can save the connector wire since it may not be defective.
结论
giggythore
于10/14/17注册
376 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 29
总计 830
