简介
This guide shows you how to operate, clean, and maintain common electric power tools so they stay safe, reliable, and ready for years of service. You will learn essential safety checks, routine care, and troubleshooting tips for a phase tester, multimeter, cordless drill-driver, bench grinder, and shop compressor. Following these practices supports responsible ownership and the circular economy by extending each tool’s life and reducing waste.
你所需要的
步骤 1 Prepare a safe workspace
Work on a clean, dry surface with adequate lighting while wearing safety glasses and protective gloves.
步骤 2 Phase tester
Push the metal probe of the phase tester into the socket contact and lightly touch the cap to close the circuit.
A glowing lamp confirms live phase; no light indicates neutral or a fault in the outlet.
Tighten or release wire clamps evenly with the tester’s flat-blade tip during wiring work.
步骤 3 Multimeter
Insert the black lead into the COM jack and the red lead into the correct jack for voltage, resistance, or current.
Switch to continuity mode and listen for the buzzer to locate broken cables or confirm a good connection.
步骤 4 Cordless drill-driver
Fit the correct bit or accessory for the job, from screwdriving tips to wire brushes or polishing pads.
Slide the direction switch to reverse for removal and forward for tightening fasteners.
Set low speed for driving and high speed for drilling, matching clutch torque to the material to avoid stripping threads.
Choose a drill that balances well in your hand and offers enough amp-hour capacity for continuous work.
步骤 5 Bench grinder and rotary tool
Set the bench grinder to low RPM when working on plastic or heat-sensitive parts to prevent melting.
Keep the grinding wheel flat by dressing it with the supplied stone before precision sharpening.
Use the opposite wheel or a cloth buff for polishing aluminum and other non-ferrous pieces.
Attach the proper bit, burr, or brush on the rotary tool and match speed and abrasive to the material.
步骤 6 Compressor
Fit the long blower nozzle to access tight areas and blast dust from motors, fans, or circuit boards.
Clip on the tire inflator or spray gun if needed and check the built-in gauge to monitor pressure.
Test paint or cleaner flow on scrap paper and adjust the regulator knob until the pattern meets your needs.
Store the compressor in a dry area and remember it is noisy during refill cycles.
Regular cleaning, correct settings, and safe handling keep your power tools working efficiently and out of the waste stream. Refer back to this guide, read every manual, and stay connected with the repair community to extend the life of your equipment and support a more circular economy.
另外一个人完成了本指南。
