跳转到主内容
简介
The machine described below has been running almost without maintenance for 17 years and has surprisingly still produced coffee, albeit badly. However, it was completely polluted. The heating was renewed,
the grinding stones exchanged, the brewing group revised, the transmission and all moving parts after-greased, all essential seals exchanged. After that it works again excellent.
  1. Never forget: Pull the plug out!
    • Never forget: Pull the plug out!
    • Remove all attachments such as drawers, water tank, brewing unit.
    • Carefully pull the steam button out. If it is too tight, first loosen the cover (steps 2 to 4), lift slightly and then push the ratchet nose using a small screwdriver.
  2. The bean container is fixed with two Phillipps screws. Unscrew those. The adjusters of the mill and the coffee can remain. Lift the bean container up und remove it from the device.
    • The bean container is fixed with two Phillipps screws. Unscrew those. The adjusters of the mill and the coffee can remain.
    • Lift the bean container up und remove it from the device.
  3. PC 笔记本电池
    所有顶级PC品牌的电池均以我们的质量保证为后盾。
    现在开始购物
    PC 笔记本电池
    现在开始购物
  4. The lid is equipped with four screws, two at the bottom front, two at the back up. One is a Torx 10, the other cross-slot. The lid is equipped with four screws, two at the bottom front, two at the back up. One is a Torx 10, the other cross-slot. The lid is equipped with four screws, two at the bottom front, two at the back up. One is a Torx 10, the other cross-slot.
    • The lid is equipped with four screws, two at the bottom front, two at the back up. One is a Torx 10, the other cross-slot.
  5. Now the cover can be lifted off. Pull backwards, then diagonally forward. Remove the silicone hose from the water tank.
    • Now the cover can be lifted off. Pull backwards, then diagonally forward. Remove the silicone hose from the water tank.
  6. On the work table, a cloth is laid, the machine is then placed on the back. The turntable may have to be pulled out on the ground eventually. On the right side of the floor are several rectangular openings. At the third is a catch with which the complete unit is attached. This is pushed backwards, then you can pull the entire unit upwards. This sometimes gets stuck when the machine is very dirty. You have to pay attention to two things: The power cord must be able to slide freely, and the catch of the bottom drawer must not jam.
    • On the work table, a cloth is laid, the machine is then placed on the back. The turntable may have to be pulled out on the ground eventually.
    • On the right side of the floor are several rectangular openings. At the third is a catch with which the complete unit is attached. This is pushed backwards, then you can pull the entire unit upwards. This sometimes gets stuck when the machine is very dirty.
    • You have to pay attention to two things: The power cord must be able to slide freely, and the catch of the bottom drawer must not jam.
  7. A view of the unit from behind. Above left the mill, in front of that the flowmeter. On the far left is the Ulka pump, in the middle of the boilers for the fast steam, among the gearbox with the engine. Right below the heater. Right up the control electronics From the front you can see the grinder, the base plate with the recess for the support valve and the drive shaft. On the left is the fully calcified heate
    • A view of the unit from behind. Above left the mill, in front of that the flowmeter. On the far left is the Ulka pump, in the middle of the boilers for the fast steam, among the gearbox with the engine. Right below the heater. Right up the control electronics
    • From the front you can see the grinder, the base plate with the recess for the support valve and the drive shaft. On the left is the fully calcified heate
结论
Repeat the steps in the reverse order to re-mount the unit.
6等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
VauWeh
于2015年10月19日注册
73,070 信誉积分
创作了83篇指南
添加评论
浏览统计数据:
过去的24小时: 4
过去的7天: 21
过去的30天: 81
总计 2,110
