跳转到主内容
Saeco Royal brewing unit disassembly
你所需要的
  1. Saeco Royal brewing unit disassembly, Cream valve and spout: 步骤 1 中的图像 1,3 Saeco Royal brewing unit disassembly, Cream valve and spout: 步骤 1 中的图像 2,3 Saeco Royal brewing unit disassembly, Cream valve and spout: 步骤 1 中的图像 3,3
    • These parts differ in details depending on the model
    • Two screws hold the part, loosen. A seal becomes free, pick up well, better still replace later.
    • Inside is a feather and a small glass ball. Store carefully.
  2. Saeco Royal brewing unit disassembly, The brewing sieve: 步骤 2 中的图像 1,2 Saeco Royal brewing unit disassembly, The brewing sieve: 步骤 2 中的图像 2,2
    • With a 6mm Allen key (or the key that comes with the machine), the brewing sieve can be unscrewed. It strongly determines the aroma, if it is dirty the coffee tastes bad.
  3. Saeco Royal brewing unit disassembly, The upper piston: 步骤 3 中的图像 1,3 Saeco Royal brewing unit disassembly, The upper piston: 步骤 3 中的图像 2,3 Saeco Royal brewing unit disassembly, The upper piston: 步骤 3 中的图像 3,3
    • He is held in place by four latches. These impress, e.g. with a screwdriver, then the piston can be pushed down.
    • The new sealing ring is already waiting, but first it has to be cleaned properly.
  4. Saeco Royal brewing unit disassembly, Intake: 步骤 4 中的图像 1,3 Saeco Royal brewing unit disassembly, Intake: 步骤 4 中的图像 2,3 Saeco Royal brewing unit disassembly, Intake: 步骤 4 中的图像 3,3
    • Through the hole on the opposite side of the fixing screw can be solved. The inlet is plugged in and held by a latch, which you have to push away.
  5. Saeco Royal brewing unit disassembly, dismantle: 步骤 5 中的图像 1,3 Saeco Royal brewing unit disassembly, dismantle: 步骤 5 中的图像 2,3 Saeco Royal brewing unit disassembly, dismantle: 步骤 5 中的图像 3,3
    • Three screws hold the brew groups together, loosen.
    • The whole mechanics can now be broken down into three big parts. The coffee funnel can stay.
  6. Saeco Royal brewing unit disassembly, Umlenkhebel: 步骤 6 中的图像 1,2 Saeco Royal brewing unit disassembly, Umlenkhebel: 步骤 6 中的图像 2,2
    • That's the trickiest part: you have to lever this lever out of its camp. To do this you drive with a screwdriver between the lever and the carrier and press it really very strong outwards. Now he grabs out - hopefully!
  7. Saeco Royal brewing unit disassembly, Lower piston: 步骤 7 中的图像 1,1
    • Since the lever is gone you can easily pull out the piston. It has no seal.
    • The lower piston itself has no gasket. But the shaft of the piston slides in an o-ring. which is situated under the brewing chamber. It can be changed, but it´s not easy to do this.
  8. Saeco Royal brewing unit disassembly, Clean: 步骤 8 中的图像 1,1
    • That's why we did it. All parts are thoroughly cleaned. For this purpose, a solution of machine detergent is good. (Use rubber gloves!) Clean all channels with pipe cleaners. The brewing sieve is like new again! Allow to dry well.
    • Then apply new gaskets, in particular to the crema valve and piston and lubricate with food-grade grease.
    • Fat also belongs to the bearings of the rocker arm and into the slides, the piston skirt, as well as into the water inlet
结论
由衷感谢以下译者:
de en
100%
VauWeh正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
VauWeh
于10/19/15注册
186,544 声望
创作了230篇指南
团队
Repair is War on Entropy Repair is War on Entropy 的会员
Community
21 名成员
创作了979篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 59
总计 4,222
