简介
The seal on the support valve is heavily stressed. It should always be well greased and also be exchanged from time to time. In this model, the support valve is independent of the heater, there is also a version in which it is screwed to the heater.
Note: the device is opened here to replace the seals. This is a reliable but a bit cumbersome procedure. If you are very skilled and can work carefully, you May also pull off the seals and replace them directly. Use a blunt tool, being careful not to damage the valve.
你所需要的
The coffeebean supply is fixed with two screws. Unscrew them and lift it off.
There is a black rubber lid under the bean hopper that you can easily lift off, leaving a large opening.
The adjuster of the grinder has to be solved. Mark the position or just take a picture. This type is fixed with a screw, others are only sticked together.
I have a Saeco Royal SUP016R model. Just cleaned the brew unit and a 1cm rubber seal fell off and i have no idea where it came from. Now there is some leak on top of the brew unit and the coffee ratio is off. Can you please help?
To have an idea, I would need to see a picture. Use this guide: 在已经存在的问题里加入图片
VauWeh -
The screws are situated on the underneath of the cover. This type is held by four screws.
Now the cover can be raised: first grip on left and right rear side and lift about 10 cm (4 in). Sometimes the cover jams a little bit.
Solve the hoses which lead to the water tank. Perhaps you have to pull out some contacts, (e.g. the yellow-green protection lead), don´t forget to put them on again later.
The cover can be drawn aslant towards the front, sliding it over the hot water pipe.
Most repairs can be done with the cover being laid up partially , it must not be completely removed.
On some models, the support valve is bolted to the heater. There are these instructions.
The support valve is visible when the brew group has been removed. It represents the connection between the hot pressurized water and the brewing group.
Two big screws hold the valve, here 6mm Allen screws. To solve.
Careful cleaning is very beneficial to the aroma.
The valve is single in this model. Here two seals are exchanged. For other models, it is bolted directly to the heater. In this case, remove the heater and valve and unscrew the valve. You then have to replace three seals.
Unscrew the valve piece with a wrench SW 13.
Check if everything is smooth. Clean all parts well. Careful, they are sensitive.
The valve spring.
The valve stamp. Check if the gasket on the valve seat is still good. Change it if necessary.
The sliding piece.
Support seal on the thermoblock. Medium size.
Support gasket above. The biggest of the three.
Support gasket below. The smallest.
Repeat the steps in order to reassemble your device.
另外一个人完成了本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
一条评论
Wow! I dare anybody to follow these instruction for a successful repair. Terrible sequence and explanation. Just look at the pictures (they are good and clear) and try to figure out the rest.
Axxam Enni - 回复
Um „nur“ das Supportventil auszutauschen gibt es noch eine sehr viel einfachere Vorgehensweise. Dabei setzt man an das untere Ende des Supportventils einfach mit einem 7er Gabelschlüssel an und schraubt dieses raus. Bei einigen Modellen wie der Spidem Trevi Chiara gibt es zusätzlich eine Plastikfront um das Ventil, welche sich abhebeln lässt um noch besser an das Ventil zu kommen. Gleichzeitig kann man dann auch am oberen Ende einen 17er Ringschlüssel ansetzen.
ChuckNorris - 回复
