简介
Good millstones are essential for an aromatic coffee. The beans are then not squeezed but nicely cut, and the ground is finer.
你所需要的
The coffeebean supply is fixed with two screws. Unscrew them and lift it off.
There is a black rubber lid under the bean hopper that you can easily lift off, leaving a large opening.
The adjuster of the grinder has to be solved. Mark the position or just take a picture. This type is fixed with a screw, others are only sticked together.
I have a Saeco Royal SUP016R model. Just cleaned the brew unit and a 1cm rubber seal fell off and i have no idea where it came from. Now there is some leak on top of the brew unit and the coffee ratio is off. Can you please help?
To have an idea, I would need to see a picture. Use this guide: 在已经存在的问题里加入图片
VauWeh -
The screws are situated on the underneath of the cover. This type is held by four screws.
Now the cover can be raised: first grip on left and right rear side and lift about 10 cm (4 in). Sometimes the cover jams a little bit.
Solve the hoses which lead to the water tank. Perhaps you have to pull out some contacts, (e.g. the yellow-green protection lead), don´t forget to put them on again later.
The cover can be drawn aslant towards the front, sliding it over the hot water pipe.
Most repairs can be done with the cover being laid up partially , it must not be completely removed.
Note the blue markings. Turn the outer ring anti clockwise until the blue marks line up to each other.
Then the ring can be lifted off. Siphon off all ground coffee immediately.
After loosening the screw you can first lift the auger, then carefully the grinding cone. You can see the three balls of the slip clutch. Carefully lift out and keep safely.
The driver can be pulled up. Pay attention to the three springs on which the balls of the slip clutch lie, these also safe to store.
All parts are thoroughly cleaned and degreased.
The cap of the grinding ring can be removed by pushing the small notches alternately left and right with a screwdriver.
The grinding ring is fastened with clamps. Press with the screwdriver to the side, then the Mahlring can be solved.
Again, everything is cleaned well, then pressed the new ring and the lid put on.
Here are all parts.
The driver is reinstated. Then the three feathers and beads inserted. When adjusting the new grinding cone, make sure that the balls are in the recesses on the bottom.
Then insert the auger so that it engages correctly in the grooves.
Finally, insert the central bolt, push the cone down slightly and tighten the bolt. Reminder: left-hand thread, that is "falschrum".
The mounted grinding ring is inserted. At first, the markers face each other. The outer ring is turned on until a resistance can be felt. So the millstones sit on each other.
Then he is turned back about 15 stops. This is about the middle setting of the degree of grinding, but can also be fine-tuned later.
Repeat the steps in order to reassemble your device.
5等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
8条评论
Hallo,
unabhängig aller Farben und Pfeilen auf dem Mahlring bzw. Einstellring ist der Mahlring beliebig in die drei Nuten des Einstellringes einzusetzen. Danach den Einstellring im Uhrzeigersinn soweit drehen, dass Widerstand spürbar ist. Danach ca. 14 Rastungen gegen Uhrzeigersinn drehen. Feineinstellung nach Mahltest.
Achtung! Viele der neu gekauften Mahlsets sind falsch, Mahlstein und Mahlring sind nicht zueinander abgestimmt. Zu erkennen, wenn der Mahlstein im Mahlring auf glatter Fläche aufliegt und der Spalt zu Mahlring mehr als 1-2 mm groß ist.
Guten Tag,
OK-Taste funktioniert nicht mehr, anscheinend elektronische Kontakt kaputt, kann man es reparieren?
Bitte um Info
Danke schön
Schwer zu sagen, einen Versuch wäre es wert. Der Taster ist wahrscheinlich nur ein billiger Mikrotaster. Aber ist er wirklich defekt? Bei diesem Händler kann man Glück mit gebrauchten Ersatzteilen haben.
Ich würde halt aufmachen und die Steuerplatine inspizieren. Viel Glück!
VauWeh -
Wenn ich den Einstellring des Mahlwerkes 14 Raster gegen den Uhrzeigersinn gedreht habe, kann ich den oberen Mahlring noch immer anheben. Was habe ich falsch gemacht?
Der Mahlring hat drei Laschen. Diese müssen in die entsprechenden Einschnitte eingesetzt werden. Wenn man den Ring im Uhrzeigersinn dreht, greift das Gewinde über die Laschen, das sieht man auch. (Die Einschnitte sind in Schritt 6, Bild 3 zu erkennen, ziemlich mit Kaffeemehl zugesetzt, sollten sauber sein.) Der Mahlring wird dadurch nach unten gegen den Mahlkegel gedrückt. Gegen den Uhrzeigersinn drehen hebt ihn wieder ein Stück nach oben.
VauWeh -
Vielen Dank ,
meine alte Saeco Royal läuft nun wieder.
Herzliche Grüße aus Südhessen
Prima, ein Punkt für die Nachhaltigkeit! Grüße aus der nahen Pfalz.
VauWeh -
Um „nur“ das Supportventil auszutauschen gibt es noch eine sehr viel einfachere Vorgehensweise. Dabei setzt man an das untere Ende des Supportventils einfach mit einem 7er Gabelschlüssel an und schraubt dieses raus. Bei einigen Modellen wie der Spidem Trevi Chiara gibt es zusätzlich eine Plastikfront um das Ventil, welche sich abhebeln lässt um noch besser an das Ventil zu kommen. Gleichzeitig kann man dann auch am oberen Ende einen 17er Ringschlüssel ansetzen.
ChuckNorris - 回复
