跳转到主内容
加入维修社区 - 创建账户
Saeco Odeo brewing unit gasket replacement
你所需要的
  1. Saeco Odeo brewing unit gasket replacement, Brewing unit gasket: 步骤 1 中的图像 1,2 Saeco Odeo brewing unit gasket replacement, Brewing unit gasket: 步骤 1 中的图像 2,2
    • Open the hatch on the side panel and remove the brewing unit.
    添加评论
  2. Saeco Odeo brewing unit gasket replacement: 步骤 2 中的图像 1,1
    • The spout for the hot coffee is located on the top of the brewing unit. It is fastened with two screws. Underneath is the crema valve. It consists of a spring and a little glass ball. Make sure the spring is reinserted with the thin end touching the glass ball when re-assembling.
    • Remove the two Torx T10 screws on the crema valve.
    • Lift off the crema valve minding the spring and the glass ball.
    添加评论
  3. Saeco Odeo brewing unit gasket replacement: 步骤 3 中的图像 1,1
    • The upper piston is held in place in the frame with four locking pawls. Push down all four latches with a spudger, then remove the piston by pushing it downward.
    • If you want to replace the gasket, you can do this now and re-assemble the device and stop here. However, a general maintenance of the brewing unit is strongly recommended.
    • Unscrew the Torx T10 screw on the brewing sieve and remove it.
    添加评论
  4. Saeco Odeo brewing unit gasket replacement: 步骤 4 中的图像 1,3 Saeco Odeo brewing unit gasket replacement: 步骤 4 中的图像 2,3 Saeco Odeo brewing unit gasket replacement: 步骤 4 中的图像 3,3
    • There are three Torx T10 screws in deep blind holes that hold together the two parts of the brewing unit. Unscrew them and lift off the upper side panel.
    添加评论
  5. Saeco Odeo brewing unit gasket replacement: 步骤 5 中的图像 1,2 Saeco Odeo brewing unit gasket replacement: 步骤 5 中的图像 2,2
    • Now you can disassemble the brewing unit into its three main parts: the brewing unit and the two side panels.
    添加评论
  6. Saeco Odeo brewing unit gasket replacement: 步骤 6 中的图像 1,2 Saeco Odeo brewing unit gasket replacement: 步骤 6 中的图像 2,2
    • You can push out the lower piston from the brewing unit if you snap the deflection lever out of its socket with a screw driver.
    • Clean all parts with very hot water and dishwasher liquid.
    • Grease all moving parts with food grade silicone fat. Dont forget the tracks in the side panels.
    添加评论
  7. Saeco Odeo brewing unit gasket replacement: 步骤 7 中的图像 1,3 Saeco Odeo brewing unit gasket replacement: 步骤 7 中的图像 2,3 Saeco Odeo brewing unit gasket replacement: 步骤 7 中的图像 3,3
    • Take this opportunity to carefully replace the two O-rings on the support valve. The larger one is at the top. These two seals are stressed during every brewing process. Therefore, lubricate them with food-safe silicone grease.
    • On some models, the support valve is covered. In this case, you must unscrew the cover first.
    添加评论
结论
Follow the steps in reverse order to reassemble your device.
取消:我没有完成这个指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
VauWeh
于10/19/15注册
329,932 声望
创作了311篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 39
总计 3,023
