简介
The Saeco Magic Cappuccino is a simple portafilter machine. The few components can be repaired well. This usually requires removing the top cover, which is shown here.
你所需要的
You can find the model designation SIN017 on the bottom of the machine.
Pull off the steam valve knob. To do this, you must pull hard.
Remove all attachments, i.e. the water tank and the drip tray.
Pull off the Cappucinatore.
Unscrew the two Phillips screws on the back.
Lay the machine on its side. Unscrew the two Phillips screws at the front of the underside.
Lift off the top cover and set it aside.
Do not remove the cover completely. It is connected with many cables. You may be able to disconnect the yellow-green cable from the hot plate, then you have more room to move.
Work through the steps in reverse order to reassemble your device.
由衷感谢以下译者:
100%
shingle正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
