当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Locate the two 3.5 mm screws on the side of the device.
Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out.
Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook.
Refer to the prerequisite guide on removing the strap hook for instructions.
Place the PH J000 phillips head screwdriver on the head of screw; apply pressure and turn in a counter clockwise motion until screws come loose.
Place the plastic opening tool on the crack between the front and back casings.
Apply pressure by pulling down on the plastic opening tool to pry the case apart.
Wedge your fingers in the opening and slowly pull the front casing away from the bottom casing until it complete separates from the device.
Using too much force in this step can damage your device.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与4其他贡献者
于03/07/16注册
358 声望
创作了3篇指南
徽章: 12
+ 9更多徽章
MARS-LAFLEN-S16S1G3
2 名成员
创作了5篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 12
总计 337
