跳转到主内容
修复你的物品
维修的权力
商店
简介
This guides enumerates the steps of removing and replacing the front casing of the SPV Aqua 5800 Camera in order to protect the mechanisms within.
  1. Locate the two 3.5 mm screws on the side of the device. Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out. Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out.
    • Locate the two 3.5 mm screws on the side of the device.
    • Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out.
  2. Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook. Refer to the prerequisite guide on removing the strap hook for instructions.
    • Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook.
    • Refer to the prerequisite guide on removing the strap hook for instructions.
    • Place the PH J000 phillips head screwdriver on the head of screw; apply pressure and turn in a counter clockwise motion until screws come loose.
  3. Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
    Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
  4. Place the plastic opening tool on the crack between the front and back casings. Apply pressure by pulling down on the plastic opening tool to pry the case apart.
    • Place the plastic opening tool on the crack between the front and back casings.
    • Apply pressure by pulling down on the plastic opening tool to pry the case apart.
  5. Wedge your fingers in the opening and slowly pull the front casing away from the bottom casing until it complete separates from the device. Using too much force in this step can damage your device.
    • Wedge your fingers in the opening and slowly pull the front casing away from the bottom casing until it complete separates from the device.
    • Using too much force in this step can damage your device.
结论
Cheyenne Heinen
于2016年03月07日注册
337 信誉积分
创作了3篇指南
团队
Marist, Team 1-3, Laflen Spring 2016 Marist, Team 1-3, Laflen Spring 2016 的会员
MARS-LAFLEN-S16S1G3
2 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 184
