当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook.
Refer to the prerequisite guide on removing the strap hook for instructions.
Place the PH J000 phillips head screwdriver on the head of screw; apply pressure and turn in a counter clockwise motion until screws come loose.
Locate the 2 mm screw that is next to the battery compartment.
Using the PH J000 phillips head screwdriver, apply pressure to the screw head and turn in a counter clockwise motion until the screw is loose.
You do not have to completely remove the 2 mm screw. To prevent losing the screw, you may leave it loosely in its place.
Slide the flat edge of the plastic opening tool between the inner casing and the back outer casing.
Push up on the plastic opening tool so that the back casing starts to lift from the inner casing.
Lifting the casing too far may result in damage. Lift the casing slowly.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
