跳转到主内容
SRS-XB22 Battery Replacement
你所需要的
  1. SRS-XB22 Battery Replacement, Remove the front grill: 步骤 1 中的图像 1,3 SRS-XB22 Battery Replacement, Remove the front grill: 步骤 1 中的图像 2,3 SRS-XB22 Battery Replacement, Remove the front grill: 步骤 1 中的图像 3,3
    • Firstly, you need to pry the speaker grill away from the speaker.
    • Use a spudger/guitar pick to prise up each end of the grill.
    • You are trying to lift a clip at either end. (circled in red)
    • Once lifted at both ends, gently pull the grill forwards.
  2. SRS-XB22 Battery Replacement, Unscrew the speakers: 步骤 2 中的图像 1,3 SRS-XB22 Battery Replacement, Unscrew the speakers: 步骤 2 中的图像 2,3 SRS-XB22 Battery Replacement, Unscrew the speakers: 步骤 2 中的图像 3,3
    • Completely remove the grill.
    • Remove the 8 screws that hold the speakers in place.
    • Slowly pull the speakers forward to free them from the case.
  3. SRS-XB22 Battery Replacement, Remove the speakers: 步骤 3 中的图像 1,3 SRS-XB22 Battery Replacement, Remove the speakers: 步骤 3 中的图像 2,3 SRS-XB22 Battery Replacement, Remove the speakers: 步骤 3 中的图像 3,3
    • Disconnect the speaker cables from the internal circuit boards.
    • Be careful, the sockets are easy to damage
    • Remove both of the rubber gaskets from the case - one for the left speaker, one for the right.
  4. SRS-XB22 Battery Replacement, Removing the outer case.: 步骤 4 中的图像 1,3 SRS-XB22 Battery Replacement, Removing the outer case.: 步骤 4 中的图像 2,3 SRS-XB22 Battery Replacement, Removing the outer case.: 步骤 4 中的图像 3,3
    • Starting at the ends of the speaker, prise the back case away from the main unit.
    • Work your way along the front of the case.
    • Once the front in freed, work you way along the edges, freeing the whole case.
    • There is A LOT of double sided tape between the outer and inner case. It requires a lot of work to remove it.
    • The case is one piece. Although it looks as if it splits at the rear, it is sealed together.
  5. SRS-XB22 Battery Replacement, Remove the rear casing: 步骤 5 中的图像 1,2 SRS-XB22 Battery Replacement, Remove the rear casing: 步骤 5 中的图像 2,2
    • Remove the rear outer casing of the speaker.
  6. SRS-XB22 Battery Replacement, Remove the front cover: 步骤 6 中的图像 1,3 SRS-XB22 Battery Replacement, Remove the front cover: 步骤 6 中的图像 2,3 SRS-XB22 Battery Replacement, Remove the front cover: 步骤 6 中的图像 3,3
    • Remove 3 screws at either end of the speaker, so 6 screws in total.
    • Using a spudger, unclip the top and bottom plastic clips, holding the front of the speaker.
    • (I made the error and removed the illuminated surround, hence it is not in two of my pictures here - it is NOT necessary to remove it)
  7. SRS-XB22 Battery Replacement, Disconnect the front panel: 步骤 7 中的图像 1,2 SRS-XB22 Battery Replacement, Disconnect the front panel: 步骤 7 中的图像 2,2
    • Slowly pull the front panel forwards.
    • Be careful, there are 3 wires still connected.
    • Disconnect the three wires, freeing the front panel.
  8. SRS-XB22 Battery Replacement, Freeing the internal components: 步骤 8 中的图像 1,3 SRS-XB22 Battery Replacement, Freeing the internal components: 步骤 8 中的图像 2,3 SRS-XB22 Battery Replacement, Freeing the internal components: 步骤 8 中的图像 3,3
    • Lift the rubber gasket away from the unit.
    • Locate the 6 screws holding the internal structure in place.
    • Remove these 6 screws.
  9. SRS-XB22 Battery Replacement: 步骤 9 中的图像 1,3 SRS-XB22 Battery Replacement: 步骤 9 中的图像 2,3 SRS-XB22 Battery Replacement: 步骤 9 中的图像 3,3
    • Use a spudger to lift the button away from the speaker.
    • Be careful, it's held down by more sticky tape!
  10. SRS-XB22 Battery Replacement, Remove the internal structure: 步骤 10 中的图像 1,1
    • Slide the main plastic unit forward from the speaker.
    • There will still be a couple of circuit boards in the back that are connected. These are the boards for the rear panel.
  11. SRS-XB22 Battery Replacement, Remove the battery: 步骤 11 中的图像 1,3 SRS-XB22 Battery Replacement, Remove the battery: 步骤 11 中的图像 2,3 SRS-XB22 Battery Replacement, Remove the battery: 步骤 11 中的图像 3,3
    • Disconnect the battery lead from the circuit board.
    • Carefully, pull the battery out of its recess.
结论
7等其他人完成本指南。
Charlie Turner
于05/22/20注册
423 声望
撰写一个指南
4条评论
has anyone ever heard the battery lady come on by herself? could it be cause I knocked it a bit too hard accidentally while attached to backpack? I loosened something inside on board?
Jeff Sparky - 回复
So the battery type is st-05s, thank you.
Karlis Liepa - 回复
Battery order plz
Somi Rai - 回复
you can find it on amazon. this is the one im trying out tomorrow.
https://www.amazon.com/gp/product/B0BC7W...
Danah AlAwadhi -
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 44
过去 30 天: 173
总计 6,647
