跳转到主内容
加入维修社区 - 创建账户
SR405QM Battery Replacement
你所需要的
  1. SR405QM Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Gently place the instrument upside-down on a soft surface.
    • Locate the battery cavity cap and screws.
  2. SR405QM Battery Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #2 head screwdriver to unscrew both screws. Two #1 1mm long screws.
  3. SR405QM Battery Replacement: 步骤 3 中的图像 1,2 SR405QM Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the cap by lifting upwards to reveal the battery.
  4. SR405QM Battery Replacement: 步骤 4 中的图像 1,3 SR405QM Battery Replacement: 步骤 4 中的图像 2,3 SR405QM Battery Replacement: 步骤 4 中的图像 3,3
    • Gently lift the battery from the cavity.
    • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
结论
To reassemble your device, follow these instructions in reverse order with a fresh battery.
2等其他人完成本指南。
Chris Pittner
于01/11/13注册
220 声望
创作了7篇指南
团队
Cal Poly, Team 5-18, Forte Winter 2013 Cal Poly, Team 5-18, Forte Winter 2013 的会员
CPSU-FORTE-W13S5G18
4 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,307
