跳转到主内容
SONY ZS-BTG900 Subwoofer Replacement
你所需要的
  1. SONY ZS-BTG900 Subwoofer Replacement, SONY ZS-BTG900 Disassembly: 步骤 1 中的图像 1,2 SONY ZS-BTG900 Subwoofer Replacement, SONY ZS-BTG900 Disassembly: 步骤 1 中的图像 2,2
    • Lift up the handle to reveal the screws.
    • Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
  2. SONY ZS-BTG900 Subwoofer Replacement: 步骤 2 中的图像 1,3 SONY ZS-BTG900 Subwoofer Replacement: 步骤 2 中的图像 2,3 SONY ZS-BTG900 Subwoofer Replacement: 步骤 2 中的图像 3,3
    • Flip your device over.
    • Use your Phillips #2 screwdriver to remove the six 3/4inch screws.
    • In removing the screws within the two holes on the back of the device, you may want to use your shaft extension to provide extra torque as they may be very tight.
  3. SONY ZS-BTG900 Subwoofer Replacement: 步骤 3 中的图像 1,2 SONY ZS-BTG900 Subwoofer Replacement: 步骤 3 中的图像 2,2
    • Flip your device back over to access the top of the device.
    • Use your plastic opening tool to pry up and remove the panel on the top, left hand side of the device.
    • This will reveal two additional screws.
  4. SONY ZS-BTG900 Subwoofer Replacement: 步骤 4 中的图像 1,1
    • Use your Phillips #2 screwdriver to remove the two 1/2 inch screws underneath the now-removed panels.
  5. SONY ZS-BTG900 Subwoofer Replacement: 步骤 5 中的图像 1,2 SONY ZS-BTG900 Subwoofer Replacement: 步骤 5 中的图像 2,2
    • Lift off the top, beginning from the back of the device.
    • Take care when lifting the top portion as there are many wires connected to the inside of the device and you do not want to disconnect these just yet.
  6. SONY ZS-BTG900 Subwoofer Replacement: 步骤 6 中的图像 1,2 SONY ZS-BTG900 Subwoofer Replacement: 步骤 6 中的图像 2,2
    • Disconnect the CD drive ribbon cable from the top of the device.
  7. SONY ZS-BTG900 Subwoofer Replacement: 步骤 7 中的图像 1,2 SONY ZS-BTG900 Subwoofer Replacement: 步骤 7 中的图像 2,2
    • Disconnect the antenna cables.
  8. SONY ZS-BTG900 Subwoofer Replacement: 步骤 8 中的图像 1,3 SONY ZS-BTG900 Subwoofer Replacement: 步骤 8 中的图像 2,3 SONY ZS-BTG900 Subwoofer Replacement: 步骤 8 中的图像 3,3
    • Disconnect the remaining cables from the motherboard.
  9. SONY ZS-BTG900 Subwoofer Replacement: 步骤 9 中的图像 1,2 SONY ZS-BTG900 Subwoofer Replacement: 步骤 9 中的图像 2,2
    • Once you have removed the top, we will begin removing the front of the device.
    • Begin by disconnecting the 6 cables that lead from the front of the device to the motherboard.
  10. SONY ZS-BTG900 Subwoofer Replacement: 步骤 10 中的图像 1,1
    • Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
    • Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
    • Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
  11. SONY ZS-BTG900 Subwoofer Replacement: 步骤 11 中的图像 1,2 SONY ZS-BTG900 Subwoofer Replacement: 步骤 11 中的图像 2,2
    • Firmly pull off the front of device.
    • There will be a small amount of black glue. You can simply ignore this, and continue to pull, or use a sharp edge to cut the glue once you've revealed it.
  12. SONY ZS-BTG900 Subwoofer Replacement, Subwoofer: 步骤 12 中的图像 1,1
    • Begin with the front component after the disassembly prerequisite.
    • This guide is for the subwoofer seen in the middle of this image.
  13. SONY ZS-BTG900 Subwoofer Replacement: 步骤 13 中的图像 1,2 SONY ZS-BTG900 Subwoofer Replacement: 步骤 13 中的图像 2,2
    • Desolder the two connector wires off the bottom plate on the speaker.
    • Note where each cable connects.
  14. SONY ZS-BTG900 Subwoofer Replacement: 步骤 14 中的图像 1,2 SONY ZS-BTG900 Subwoofer Replacement: 步骤 14 中的图像 2,2
    • Remove the four 1/2 inch screws using a #2 Phillips screwdriver.
  15. SONY ZS-BTG900 Subwoofer Replacement: 步骤 15 中的图像 1,2 SONY ZS-BTG900 Subwoofer Replacement: 步骤 15 中的图像 2,2
    • Firmly grab the end of the subwoofer.
    • Pull up and out to remove it.
结论
另外一个人完成了本指南。
一条评论
You completely forgot about the screws in the CD Drive. Nearly broke the top plastic prying on it.
Nick B - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,314
