跳转到主内容
SONY ZS-BTG900 Remote Motherboard Replacement
你所需要的
  1. SONY ZS-BTG900 Remote Motherboard Replacement, Remote Motherboard: 步骤 1 中的图像 1,2 SONY ZS-BTG900 Remote Motherboard Replacement, Remote Motherboard: 步骤 1 中的图像 2,2
    • Flip the remote and remove the backing.
  2. SONY ZS-BTG900 Remote Motherboard Replacement: 步骤 2 中的图像 1,2 SONY ZS-BTG900 Remote Motherboard Replacement: 步骤 2 中的图像 2,2
    • Locate the screw behind the battery pack.
    • Use a Phillips size 1 screwdriver to remove the 5/16in screw located inside the battery port.
  3. SONY ZS-BTG900 Remote Motherboard Replacement: 步骤 3 中的图像 1,2 SONY ZS-BTG900 Remote Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use the plastic opening tool along the seam on the side of the remote until you hear a click. This means that the plastic tabs holding the remote together are coming loose.
    • Do this until the top half of the remote comes loose.
  4. SONY ZS-BTG900 Remote Motherboard Replacement: 步骤 4 中的图像 1,2 SONY ZS-BTG900 Remote Motherboard Replacement: 步骤 4 中的图像 2,2
    • Carefully remove the top to reveal the button covers and the remote control board.
  5. SONY ZS-BTG900 Remote Motherboard Replacement: 步骤 5 中的图像 1,2 SONY ZS-BTG900 Remote Motherboard Replacement: 步骤 5 中的图像 2,2
    • Lift the chip out of the plastic casing to replace it.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 437
