简介
This guide will allow you to detach the faceplate in order to replace existing buttons or screen on your Sony Ericsson W890i
  1. Flick the two lock tabs into the unlocked positions by pushing each button forward.
    • Flick the two lock tabs into the unlocked positions by pushing each button forward.
  2. Pop the back cover up using the groove on the top of the phone.
    • Pop the back cover up using the groove on the top of the phone.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. You can now access the phone's battery.
    • You can now access the phone's battery.
    • Using a spudger, remove the battery and set it aside.
  5. Remove the two small rubber pieces that cover the lower screws. Using a T-6 Torx wrench or screwdriver, remove all four of the small screws at the top and bottom corners on the back of the phones.
    • Remove the two small rubber pieces that cover the lower screws.
    • Using a T-6 Torx wrench or screwdriver, remove all four of the small screws at the top and bottom corners on the back of the phones.
  6. Gently pry off the faceplate using a plastic opening tool.
    • Gently pry off the faceplate using a plastic opening tool.
    • Insert the plastic opening tool into the middle of the front and back panels of the phone.
  7. Seperate the front and back panels that were pryed open with the plastic opening tool.
    • Seperate the front and back panels that were pryed open with the plastic opening tool.
结论
Bob
于2013年04月15日注册
301 信誉积分
创作了3篇指南
团队
SUNY Cortland, Team 1-3, Getto Spring 2013 SUNY Cortland, Team 1-3, Getto Spring 2013 的会员
SUNYCORT-GETTO-S13S1G3
3 名成员
创作了8篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 9
总计 649
