跳转到主内容
SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement, How to Open and Close Housing (SOMNOcomfort and SOMNObalance Ventilator): 步骤 1 中的图像 1,1
    • Remove the covering cap. (pg. 23)
  2. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: 步骤 2 中的图像 1,1
    • Place the unit upside down on a non-slip surface and remove the six screws. (pg. 23)
  3. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: 步骤 3 中的图像 1,1
    • Remove the lower part of the housing with a swiveling motion away to the side. Note the SOMNOcomfort series uses a shorter circuit board than the balance series ventilator. (pg. 23)
  4. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: 步骤 4 中的图像 1,3 SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: 步骤 4 中的图像 2,3 SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: 步骤 4 中的图像 3,3
    • Remove the connector (X1) from the circuit board.
    • Pull the connecting cable (64) from its mount.
    • Now set aside the lower part of the housing. (pg. 23)
  5. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: 步骤 5 中的图像 1,2 SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: 步骤 5 中的图像 2,2
    • Next, how to close the compartment and reverse the process.
    • Hold the lower part of the housing to the upper part at an angle
    • Attach the connector (X1) to the main circuit board. When doing so the connector’s nub has to point towards the lock. (pg. 24)
  6. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: 步骤 6 中的图像 1,2 SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: 步骤 6 中的图像 2,2
    • Properly align the main circuit board inside the unit.
    • Attach the connecting cable (64) to its mount (pg. 24)
  7. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: 步骤 7 中的图像 1,1
    • Place the lower part of the housing on the upper part (47). Please make sure the main circuit board (44) is aligned properly, and that the connecting cable (64) is not being squeezed anywhere. (pg. 24)
  8. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: 步骤 8 中的图像 1,1
    • Now reattach the upper part of the housing by tightening the six screws. (pg. 24)
  9. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: 步骤 9 中的图像 1,1
    • Insert the covering cap. (pg. 24)
  10. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement, Fuse: 步骤 10 中的图像 1,1
    • Open the unit (refer to the guide "How to Open and Close Housing")
  11. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: 步骤 11 中的图像 1,2 SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: 步骤 11 中的图像 2,2
    • Remove the defective fuse(76 or 77) and replace with a new one. (pg. 27)
    • Ensure the correct amperage is used. Use fuses mentioned in the Replacement parts list only. Using other fuses may cause damage to the main circuit board.
    • 76 refers to the fuse in SOMNObalance. 77 refers to the fuse in SOMNOcomfort.
  12. SOMNOcomfort and SOMNObalance Ventilator Fuse Replacement: 步骤 12 中的图像 1,1
    • Close the Unit (refer to the guide "How to Open and Close Housing").
结论
Check that everything is working properly after having successfully replaced the fuse.
Katie Steidl
于05/04/20注册
97 声望
撰写一个指南
团队
Cal Poly, Team S1-G3, Zimmerman Spring 2020 Cal Poly, Team S1-G3, Zimmerman Spring 2020 的会员
CPSU-ZIMMERMAN-S20S1G3
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 170
