跳转到主内容
加入维修社区 - 创建账户
SN Programmable (SV-336) Battery Replacement
你所需要的
  1. SN Programmable (SV-336) Battery Replacement, Getting started: 步骤 1 中的图像 1,1
    • For this procedure you will need:
    • An SN Programmable
    • A #1 Phillips screwdriver - the screws are actually #2, but some #2 screwdrivers may be too thick to reach into the screw holes.
    • A small flat-head screwdriver to lift the battery out of its holder.
    • A flat blade to pop/crumble the rubber feet off the bottom of the controller.
    • A new CR2032 coin cell battery.
    • Disregard the ominous black circle over the joystick handle in all the photos - it's difficult to take photos of extremely shiny things without showing off the entirety of your untidy workspace.
  2. SN Programmable (SV-336) Battery Replacement, Unscrewing the case: 步骤 2 中的图像 1,1
    • There are five screws to undo - one in the bottom centre (just above the two smaller holes), and four underneath the rubber feet. You will need to peel the feet off the case to access these - mine were so aged and stiffened they crumbled apart when I tried. You can optionally replace these later with new rubber feet up to 14mm in diameter.
    • Push down hard when starting to loosen each a screw. They have been set in hard, cheap plastic for possibly decades, and may take some force to start moving.
  3. SN Programmable (SV-336) Battery Replacement, Removing the top cover: 步骤 3 中的图像 1,1
    • Once you've removed all five screws from the bottom, turn the controller upright again and remove the top plastic cover - it should lift off easily. The side buttons are likely to pop out - make sure you keep both the grey plastic button and the spring. Take care to ease the cable out from the top of the case as it may be firmly fitted into it.
  4. SN Programmable (SV-336) Battery Replacement: 步骤 4 中的图像 1,3 SN Programmable (SV-336) Battery Replacement: 步骤 4 中的图像 2,3 SN Programmable (SV-336) Battery Replacement: 步骤 4 中的图像 3,3
    • The CR2032 battery is in a holder in a separate circuit board at the front edge of the controller. Use a small flat-head screwdriver to lever it upwards, then slide it out of its holder to the right.
    • Slide the replacement battery in.
  5. SN Programmable (SV-336) Battery Replacement, Re-install the top cover: 步骤 5 中的图像 1,1
    • Re-install the top cover of the controller, taking care to line up the cable and the "slow", "set", "mode" and "start" buttons with their respective holes.
    • Leave the side buttons out, for now.
    • Flip the controller over and re-install all five screws (and replacement rubber feet, if need be).
  6. SN Programmable (SV-336) Battery Replacement, Re-install the side buttons: 步骤 6 中的图像 1,1
    • Now's the time to pop the side buttons back in. Pop the spring back over the button's shaft, and firmly press the button back into place. It will take some force to do, but it will snap back in.
结论
You're all done! Time to plug your controller in and double-check all the buttons work correctly. The SN Programmable's screen will show a little box to represent each button when it's pushed. Use this to make sure pressing each button produces an input of some kind.
timixretroplays
于05/05/23注册
133 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 38
总计 467
