跳转到主内容
SM Santa Marin hand watch Battery Replacement
你所需要的
  1. SM Santa Marin hand watch Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Take apart the steel strap for the watch by using the round head (SIM) screwdriver. Then pull out the screw.
  2. SM Santa Marin hand watch Battery Replacement: 步骤 2 中的图像 1,1
    • Remove four screws from the back cover using the Y000 screwdriver .
  3. SM Santa Marin hand watch Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover of the watch using the opening tool.
  4. SM Santa Marin hand watch Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the plastic gasket from on top of the battery using the opening tool.
  5. SM Santa Marin hand watch Battery Replacement: 步骤 5 中的图像 1,1
    • Loosen the battery bracket from the watch by placing the 1mm flathead screwdriver under and lifting carefully.
  6. SM Santa Marin hand watch Battery Replacement: 步骤 6 中的图像 1,2 SM Santa Marin hand watch Battery Replacement: 步骤 6 中的图像 2,2
    • Take the old battery out using the plastic opening tool or spudger.
结论
Aziz Zabarmawi
于10/07/19注册
133 声望
撰写一个指南
一条评论
It's amazing and also work as a machenic for me
Talha - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 16
总计 885
