跳转到主内容
SKYTEX SP1020 Rear Case Replacement
你所需要的
  1. SKYTEX SP1020 Rear Case Replacement, Rear Case: 步骤 1 中的图像 1,2 SKYTEX SP1020 Rear Case Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Prior to any repairs make sure that you are familiar with the device as well as the location of its buttons and ports.
    • Turn off device prior to continuing to further steps.
  2. SKYTEX SP1020 Rear Case Replacement: 步骤 2 中的图像 1,3 SKYTEX SP1020 Rear Case Replacement: 步骤 2 中的图像 2,3 SKYTEX SP1020 Rear Case Replacement: 步骤 2 中的图像 3,3
    • Set the tablet back panel facing down, with the SKYTEX logo facing you. You will find that this step will start from the right side of the device.
    • Insert the plastic opening tool between the bottom seam of the back panel and the micro SD port. The tool's edge should point toward the rear panel to prevent any scratching or damage.
    • Follow up with the plastic opening tool, releasing the clips as you go all the way around the device.
  3. SKYTEX SP1020 Rear Case Replacement: 步骤 3 中的图像 1,1
    • The clips will be released in the order specified as the spudger tool is moved along the seam around the device.
  4. SKYTEX SP1020 Rear Case Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to pry the speakers out of the rear case.
    • The rear case will now be free from the rest of the device.
结论
另外一个人完成了本指南。
yuriy16899
于04/20/15注册
243 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-6, Miles Spring 2015 UMass Dartmouth, Team 1-6, Miles Spring 2015 的会员
UMASSD-MILES-S15S1G6
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 156
