跳转到主内容
SHARP EL-546XT Battery Replacement
你所需要的
  1. SHARP EL-546XT Battery Replacement, Battery: 步骤 1 中的图像 1,2 SHARP EL-546XT Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the calculator on a clean workspace with the back facing up.
  2. SHARP EL-546XT Battery Replacement: 步骤 2 中的图像 1,3 SHARP EL-546XT Battery Replacement: 步骤 2 中的图像 2,3 SHARP EL-546XT Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the calculator cover if you had it on.
    • Turn off the calculator using the 2nd F button then clicking the ON button.
  3. SHARP EL-546XT Battery Replacement: 步骤 3 中的图像 1,3 SHARP EL-546XT Battery Replacement: 步骤 3 中的图像 2,3 SHARP EL-546XT Battery Replacement: 步骤 3 中的图像 3,3
    • Put the calculator cover back on to ensure you don't accidentally press any buttons.
    • Remove the screws from the battery door.
    • Do not remove the other screws as they are not for the battery compartment.
  4. SHARP EL-546XT Battery Replacement: 步骤 4 中的图像 1,2 SHARP EL-546XT Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the battery door from the calculator.
  5. SHARP EL-546XT Battery Replacement: 步骤 5 中的图像 1,3 SHARP EL-546XT Battery Replacement: 步骤 5 中的图像 2,3 SHARP EL-546XT Battery Replacement: 步骤 5 中的图像 3,3
    • Use a spudger to gently push the coin battery out through the small hole located below the battery.
    • Be careful not to apply too much force when pushing the old battery out to avoid damaging the calculator or the battery compartment.
  6. SHARP EL-546XT Battery Replacement: 步骤 6 中的图像 1,3 SHARP EL-546XT Battery Replacement: 步骤 6 中的图像 2,3 SHARP EL-546XT Battery Replacement: 步骤 6 中的图像 3,3
    • Gently insert the new battery into the battery compartment.
    • Handle the new batteries with care.
  7. SHARP EL-546XT Battery Replacement: 步骤 7 中的图像 1,2 SHARP EL-546XT Battery Replacement: 步骤 7 中的图像 2,2
    • Ensure the battery is properly slotted in the battery compartment.
    • Close the battery compartment with the battery door.
  8. SHARP EL-546XT Battery Replacement: 步骤 8 中的图像 1,3 SHARP EL-546XT Battery Replacement: 步骤 8 中的图像 2,3 SHARP EL-546XT Battery Replacement: 步骤 8 中的图像 3,3
    • Attach the screws back to the battery door.
  9. SHARP EL-546XT Battery Replacement: 步骤 9 中的图像 1,3 SHARP EL-546XT Battery Replacement: 步骤 9 中的图像 2,3 SHARP EL-546XT Battery Replacement: 步骤 9 中的图像 3,3
    • Take the calculator out of the cover.
    • Turn on the calculator and test if it's functioning.
终点
Mithunan Sivagnanam
于05/22/23注册
169 声望
撰写一个指南
团队
York University, Team A-11, Allen Summer 2023 York University, Team A-11, Allen Summer 2023 的会员
YORK-ALLEN-SU23SAG11
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 26
总计 522
