跳转到主内容
SHARP EL-531XT Battery Replacement
你所需要的
  1. SHARP EL-531XT Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Press the [2ndF] button.
    • Then press [ON/C][Off] button marked in orange to turn off the calculator.
  2. SHARP EL-531XT Battery Replacement: 步骤 2 中的图像 1,1
    • Flip the calculator over so the backside is facing up.
    • Use the Phillips #0 screwdriver to remove two 5 mm screws located at the top of the calculator.
  3. SHARP EL-531XT Battery Replacement: 步骤 3 中的图像 1,1
    • Lift the small cover up and pull it off.
  4. SHARP EL-531XT Battery Replacement: 步骤 4 中的图像 1,1
    • Use a nylon or plastic spudger to gently pry the old battery out of the socket.
    • Avoid using a metal spudger or screwdriver to remove the battery. Using metal tools on batteries and other delicate components is dangerous and could result in damage to either the components or the device.
  5. SHARP EL-531XT Battery Replacement: 步骤 5 中的图像 1,1
    • Gently put in the new battery.
  6. SHARP EL-531XT Battery Replacement: 步骤 6 中的图像 1,1
    • Close the small cover and replace the two 5 mm Phillips #0 screws.
    • Make sure to tighten both screws equally.
  7. SHARP EL-531XT Battery Replacement: 步骤 7 中的图像 1,1
    • Turn the calculator over and test all the functions.
结论
另外一个人完成了本指南。
Muhammad Raja
于09/13/23注册
166 声望
撰写一个指南
团队
York University, Team 1-23, O'Regan Fall 2023 York University, Team 1-23, O'Regan Fall 2023 的会员
YORK-O'REGAN-F23S1G23
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 119
