跳转到主内容
SHARK WANDVAC WV205 Battery Replacement
你所需要的
  1. SHARK WANDVAC WV205 Battery Replacement, Battery: 步骤 1 中的图像 1,2 SHARK WANDVAC WV205 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Push the sliding button to open the dirt capsule to empty it out.
    • Ensure to do this over a garbage can/bag to prevent a mess.
  2. SHARK WANDVAC WV205 Battery Replacement: 步骤 2 中的图像 1,2 SHARK WANDVAC WV205 Battery Replacement: 步骤 2 中的图像 2,2
    • Using a coin or other thin item, such as a guitar pick, push the cap at the end of the vacuum out. Switch between sides to make it come out evenly.
    • This could take more time than expected.
  3. SHARK WANDVAC WV205 Battery Replacement: 步骤 3 中的图像 1,2 SHARK WANDVAC WV205 Battery Replacement: 步骤 3 中的图像 2,2
    • Once the battery is popped out, carefully pull it out.
  4. SHARK WANDVAC WV205 Battery Replacement: 步骤 4 中的图像 1,2 SHARK WANDVAC WV205 Battery Replacement: 步骤 4 中的图像 2,2
    • To properly store and then dispose of the battery put it in a clear plastic bag.
  5. SHARK WANDVAC WV205 Battery Replacement: 步骤 5 中的图像 1,2 SHARK WANDVAC WV205 Battery Replacement: 步骤 5 中的图像 2,2
    • Slot your replacement battery where the old one was.
    • Once inside, push hard on the end until you hear a click.
  6. SHARK WANDVAC WV205 Battery Replacement: 步骤 6 中的图像 1,1
    • Test the vacuum to ensure the replacement succeeded.
结论
To properly dispose of the old battery consult your cities policies on lithium ion battery disposal.
Nicolaas
于01/16/24注册
133 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 38
总计 129
