跳转到主内容
SGIN X15S Motherboard Replacement
你所需要的
  1. SGIN X15S Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,3 SGIN X15S Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,3 SGIN X15S Motherboard Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Remove the eight top and middle 7.3 mm screws using the Phillips #0 screwdriver.
    • Remove the six bottom and side 4.4 mm screws using the Phillips #0 screwdriver.
  2. SGIN X15S Motherboard Replacement: 步骤 2 中的图像 1,3 SGIN X15S Motherboard Replacement: 步骤 2 中的图像 2,3 SGIN X15S Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use the nylon spudger to gently pry a bit of the back panel open. With the opening pick, go all the way around until the back panel is loose.
    • Pull the back panel off the laptop.
  3. SGIN X15S Motherboard Replacement, Unplugging SGIN X15S Battery: 步骤 3 中的图像 1,2 SGIN X15S Motherboard Replacement, Unplugging SGIN X15S Battery: 步骤 3 中的图像 2,2
    • Gently remove the tape holding the battery's cord to the motherboard, followed by the tape in the middle of the cord.
    • If your battery is swollen, halt this guide and follow the swollen battery disposal guide.
  4. SGIN X15S Motherboard Replacement: 步骤 4 中的图像 1,3 SGIN X15S Motherboard Replacement: 步骤 4 中的图像 2,3 SGIN X15S Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use the nylon spudger to detach the battery from the motherboard.
  5. SGIN X15S Motherboard Replacement, Unplugging Wires From SGIN X15S Motherboard: 步骤 5 中的图像 1,3 SGIN X15S Motherboard Replacement, Unplugging Wires From SGIN X15S Motherboard: 步骤 5 中的图像 2,3 SGIN X15S Motherboard Replacement, Unplugging Wires From SGIN X15S Motherboard: 步骤 5 中的图像 3,3
    • Using the nylon spudger, unclip the clip holding the touchpad cable down.
    • Disconnect the touchpad cable.
  6. SGIN X15S Motherboard Replacement: 步骤 6 中的图像 1,3 SGIN X15S Motherboard Replacement: 步骤 6 中的图像 2,3 SGIN X15S Motherboard Replacement: 步骤 6 中的图像 3,3
    • Using the nylon spudger, unclip the clip holding the keyboard ribbon cable in place.
    • Disconnect the keyboard ribbon cable.
  7. SGIN X15S Motherboard Replacement: 步骤 7 中的图像 1,3 SGIN X15S Motherboard Replacement: 步骤 7 中的图像 2,3 SGIN X15S Motherboard Replacement: 步骤 7 中的图像 3,3
    • Using the nylon spudger, unclip the clip holding the screen cable in place.
    • Disconnect the screen cable from the motherboard.
  8. SGIN X15S Motherboard Replacement: 步骤 8 中的图像 1,2 SGIN X15S Motherboard Replacement: 步骤 8 中的图像 2,2
    • Using the tweezers, grab the wire connector.
    • When removing connectors, be sure to grip the edges of the wire connector and not the wires themselves.
    • With the tweezers in place, push away from the motherboard to disconnect the wire.
  9. SGIN X15S Motherboard Replacement: 步骤 9 中的图像 1,3 SGIN X15S Motherboard Replacement: 步骤 9 中的图像 2,3 SGIN X15S Motherboard Replacement: 步骤 9 中的图像 3,3
    • Using the angled tweezers, firmly grip the black Wi-Fi cable.
    • With a firm grip, pull the black Wi-Fi cable off the motherboard.
    • Do the same to the grey cable.
  10. SGIN X15S Motherboard Replacement, Heat Sink: 步骤 10 中的图像 1,3 SGIN X15S Motherboard Replacement, Heat Sink: 步骤 10 中的图像 2,3 SGIN X15S Motherboard Replacement, Heat Sink: 步骤 10 中的图像 3,3
    • Remove the four 3 mm screws holding the heatsink in place using a Phillips #0 screwdriver.
    • Lift and remove the heatsink.
    • There is thermal paste on the bottom that will need to be cleaned off and reapplied if the motherboard is replaced.
  11. SGIN X15S Motherboard Replacement, M.2 SSD: 步骤 11 中的图像 1,2 SGIN X15S Motherboard Replacement, M.2 SSD: 步骤 11 中的图像 2,2
    • Remove the single 3 mm screw holding the SSD in place using a Phillips #0 screwdriver.
  12. SGIN X15S Motherboard Replacement: 步骤 12 中的图像 1,3 SGIN X15S Motherboard Replacement: 步骤 12 中的图像 2,3 SGIN X15S Motherboard Replacement: 步骤 12 中的图像 3,3
    • Give the SSD a little upward force near the screw side so that it is bent at an angle.
    • Pull the SSD out of its slot.
  13. SGIN X15S Motherboard Replacement, Motherboard: 步骤 13 中的图像 1,3 SGIN X15S Motherboard Replacement, Motherboard: 步骤 13 中的图像 2,3 SGIN X15S Motherboard Replacement, Motherboard: 步骤 13 中的图像 3,3
    • Using the nylon spudger, unclip the clip holding down the ribbon cable.
    • Disconnect the ribbon cable.
  14. SGIN X15S Motherboard Replacement: 步骤 14 中的图像 1,2 SGIN X15S Motherboard Replacement: 步骤 14 中的图像 2,2
  15. SGIN X15S Motherboard Replacement: 步骤 15 中的图像 1,3 SGIN X15S Motherboard Replacement: 步骤 15 中的图像 2,3 SGIN X15S Motherboard Replacement: 步骤 15 中的图像 3,3
    • Using the Phillips #0 screwdriver remove the six 3 mm screws.
    • Carefully grab the sides of the motherboard and make sure not to touch any of the components on the top or bottom.
    • Remove the motherboard.
结论
To reassemble your device, follow these instructions in reverse order and remember to reapply thermal paste on the heatsink.
JadenS
于02/25/25注册
637 声望
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 180
