跳转到主内容
SGIN X15S Fan Replacement
你所需要的
  1. SGIN X15S Fan Replacement, Back Panel: 步骤 1 中的图像 1,3 SGIN X15S Fan Replacement, Back Panel: 步骤 1 中的图像 2,3 SGIN X15S Fan Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Remove the eight top and middle 7.3 mm screws using the Phillips #0 screwdriver.
    • Remove the six bottom and side 4.4 mm screws using the Phillips #0 screwdriver.
  2. SGIN X15S Fan Replacement: 步骤 2 中的图像 1,3 SGIN X15S Fan Replacement: 步骤 2 中的图像 2,3 SGIN X15S Fan Replacement: 步骤 2 中的图像 3,3
    • Use the nylon spudger to gently pry a bit of the back panel open. With the opening pick, go all the way around until the back panel is loose.
    • Pull the back panel off the laptop.
  3. SGIN X15S Fan Replacement, Unplugging SGIN X15S Battery: 步骤 3 中的图像 1,2 SGIN X15S Fan Replacement, Unplugging SGIN X15S Battery: 步骤 3 中的图像 2,2
    • Gently remove the tape holding the battery's cord to the motherboard, followed by the tape in the middle of the cord.
    • If your battery is swollen, halt this guide and follow the swollen battery disposal guide.
  4. SGIN X15S Fan Replacement: 步骤 4 中的图像 1,3 SGIN X15S Fan Replacement: 步骤 4 中的图像 2,3 SGIN X15S Fan Replacement: 步骤 4 中的图像 3,3
    • Use the nylon spudger to detach the battery from the motherboard.
  5. SGIN X15S Fan Replacement, Fan: 步骤 5 中的图像 1,2 SGIN X15S Fan Replacement, Fan: 步骤 5 中的图像 2,2
    • Using the tweezers, grab the wire connector.
    • When removing connectors, be sure to grip the edges of the wire connector and not the wires themselves.
    • With the tweezers in place, push away from the motherboard to disconnect the wire.
  6. SGIN X15S Fan Replacement: 步骤 6 中的图像 1,3 SGIN X15S Fan Replacement: 步骤 6 中的图像 2,3 SGIN X15S Fan Replacement: 步骤 6 中的图像 3,3
    • Remove the three 5.5 mm screws holding the fan in place using a Phillips #0 screwdriver.
    • Pull the thermal pad off of the fan.
    • Pull the fan, hooked by magnets, away from the heatsink.
结论
JadenS
于02/25/25注册
637 声望
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 23
总计 145
