跳转到主内容
SGIN X15S Battery Replacement
你所需要的
  1. SGIN X15S Battery Replacement, Back Panel: 步骤 1 中的图像 1,3 SGIN X15S Battery Replacement, Back Panel: 步骤 1 中的图像 2,3 SGIN X15S Battery Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Remove the eight top and middle 7.3 mm screws using the Phillips #0 screwdriver.
    • Remove the six bottom and side 4.4 mm screws using the Phillips #0 screwdriver.
  2. SGIN X15S Battery Replacement: 步骤 2 中的图像 1,3 SGIN X15S Battery Replacement: 步骤 2 中的图像 2,3 SGIN X15S Battery Replacement: 步骤 2 中的图像 3,3
    • Use the nylon spudger to gently pry a bit of the back panel open. With the opening pick, go all the way around until the back panel is loose.
    • Pull the back panel off the laptop.
  3. SGIN X15S Battery Replacement, Unplugging SGIN X15S Battery: 步骤 3 中的图像 1,2 SGIN X15S Battery Replacement, Unplugging SGIN X15S Battery: 步骤 3 中的图像 2,2
    • Gently remove the tape holding the battery's cord to the motherboard, followed by the tape in the middle of the cord.
    • If your battery is swollen, halt this guide and follow the swollen battery disposal guide.
  4. SGIN X15S Battery Replacement: 步骤 4 中的图像 1,3 SGIN X15S Battery Replacement: 步骤 4 中的图像 2,3 SGIN X15S Battery Replacement: 步骤 4 中的图像 3,3
    • Use the nylon spudger to detach the battery from the motherboard.
  5. SGIN X15S Battery Replacement, Battery: 步骤 5 中的图像 1,3 SGIN X15S Battery Replacement, Battery: 步骤 5 中的图像 2,3 SGIN X15S Battery Replacement, Battery: 步骤 5 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove the three 4.4 mm screws attached to the battery.
    • Remove the battery.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 19
总计 236
