跳转到主内容
SG 552-1 Commando Barrel Replacement
你所需要的
  1. SG 552-1 Commando Barrel Replacement, Barrel: 步骤 1 中的图像 1,2 SG 552-1 Commando Barrel Replacement, Barrel: 步骤 1 中的图像 2,2
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Pull the hand guard off.
  2. SG 552-1 Commando Barrel Replacement: 步骤 2 中的图像 1,2 SG 552-1 Commando Barrel Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun. There should be four total.
  3. SG 552-1 Commando Barrel Replacement: 步骤 3 中的图像 1,2 SG 552-1 Commando Barrel Replacement: 步骤 3 中的图像 2,2
    • Locate the button to fold over the folding stock and fold over the folding stock.
    • Using a Phillips #1 screwdriver, remove the 20mm screw located behind the folding stock.
  4. SG 552-1 Commando Barrel Replacement: 步骤 4 中的图像 1,2 SG 552-1 Commando Barrel Replacement: 步骤 4 中的图像 2,2
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw located directly underneath the cocking lever.
    • Remove the 8mm screw beside the one you just removed.
  5. SG 552-1 Commando Barrel Replacement: 步骤 5 中的图像 1,2 SG 552-1 Commando Barrel Replacement: 步骤 5 中的图像 2,2
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
  6. SG 552-1 Commando Barrel Replacement: 步骤 6 中的图像 1,3 SG 552-1 Commando Barrel Replacement: 步骤 6 中的图像 2,3 SG 552-1 Commando Barrel Replacement: 步骤 6 中的图像 3,3
    • Pull the barrel out from the cover.
    • Remove the pieces at the end of the barrel.
  7. SG 552-1 Commando Barrel Replacement: 步骤 7 中的图像 1,2 SG 552-1 Commando Barrel Replacement: 步骤 7 中的图像 2,2
    • Remove the remaining pieces of on the ends of the barrel.
结论
Laura Schulz
于10/05/12注册
1 声望
撰写一个指南
团队
Cal Poly, Team 18-41, Regan Fall 2012 Cal Poly, Team 18-41, Regan Fall 2012 的会员
CPSU-REGAN-F12S18G41
6 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,715
