跳转到主内容
SEGA Genesis Flashback Controller Back Cover Replacement
你所需要的
  1. SEGA Genesis Flashback Controller Back Cover Replacement, Controller Back Cover: 步骤 1 中的图像 1,3 SEGA Genesis Flashback Controller Back Cover Replacement, Controller Back Cover: 步骤 1 中的图像 2,3 SEGA Genesis Flashback Controller Back Cover Replacement, Controller Back Cover: 步骤 1 中的图像 3,3
    • Hold the controller with the bottom plate facing up, and gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
    • Remove the screws on the back of the controller with the Phillips #000 screwdriver.
    • Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
结论
2等其他人完成本指南。
Omar Shorab
于04/23/18注册
261 声望
创作了2篇指南
团队
Cal Poly, Team S24-G12, Maness Spring 2018 Cal Poly, Team S24-G12, Maness Spring 2018 的会员
CPSU-MANESS-S18S24G12
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 457
