跳转到主内容
SEAT Cordoba II (2002-2009) Air Filter Replacement
你所需要的
  1. SEAT Cordoba II (2002-2009) Air Filter Replacement, Remove the two indicated screws: 步骤 1 中的图像 1,1
    • Unscrew the two phillips head screws. Use the reversible screwdriver that came with the car.
  2. SEAT Cordoba II (2002-2009) Air Filter Replacement, Open the cover: 步骤 2 中的图像 1,2 SEAT Cordoba II (2002-2009) Air Filter Replacement, Open the cover: 步骤 2 中的图像 2,2
    • Pull the cover up and slightly to the right.
    • Here we have to replace the filter. Lift the filter up. It comes off without difficulty.
  3. SEAT Cordoba II (2002-2009) Air Filter Replacement, Clean and replace: 步骤 3 中的图像 1,2 SEAT Cordoba II (2002-2009) Air Filter Replacement, Clean and replace: 步骤 3 中的图像 2,2
    • Clean all of the rubbish and insects that are inside.
    • Place the new filter, fitting the rubber contour with the gap.
  4. SEAT Cordoba II (2002-2009) Air Filter Replacement, Replacing the cover and the screws: 步骤 4 中的图像 1,3 SEAT Cordoba II (2002-2009) Air Filter Replacement, Replacing the cover and the screws: 步骤 4 中的图像 2,3 SEAT Cordoba II (2002-2009) Air Filter Replacement, Replacing the cover and the screws: 步骤 4 中的图像 3,3
    • Fit the two tabs in their places.
    • Once you've done that, put the two screws into their places and tightly screw them in. Finally, check to see that they are completely screwed in.
终点
2等其他人完成本指南。
由衷感谢以下译者:
es en
100%
Mr. Bean正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Jonatan M
于03/17/18注册
500 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 33
过去 30 天: 93
总计 4,569
