跳转到主内容
Ryobi RJ1861V Saw Gear Assembly Replacement
你所需要的
  1. Ryobi RJ1861V Saw Gear Assembly Replacement, Saw Bar Assembly: 步骤 1 中的图像 1,1
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Saw Gear Assembly Replacement: 步骤 2 中的图像 1,2 Ryobi RJ1861V Saw Gear Assembly Replacement: 步骤 2 中的图像 2,2
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Saw Gear Assembly Replacement: 步骤 3 中的图像 1,1
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Saw Gear Assembly Replacement: 步骤 4 中的图像 1,1
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Saw Gear Assembly Replacement: 步骤 5 中的图像 1,1
    • Remove the backside panel.
  6. Ryobi RJ1861V Saw Gear Assembly Replacement: 步骤 6 中的图像 1,1
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
  7. Ryobi RJ1861V Saw Gear Assembly Replacement: 步骤 7 中的图像 1,1
    • Lift the assembly bar up and out of the chassis.
  8. Ryobi RJ1861V Saw Gear Assembly Replacement, Assembly Bar Bearing: 步骤 8 中的图像 1,1
    • Begin with the top of the device facing up.
  9. Ryobi RJ1861V Saw Gear Assembly Replacement: 步骤 9 中的图像 1,1
    • Insert needle nose pliers to remove the retaining pin at the top of the bearing.
  10. Ryobi RJ1861V Saw Gear Assembly Replacement: 步骤 10 中的图像 1,1
    • Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
  11. Ryobi RJ1861V Saw Gear Assembly Replacement, Saw Gear Assembly: 步骤 11 中的图像 1,1
    • After you remove the bearing, stand the device with the gear assembly facing up.
  12. Ryobi RJ1861V Saw Gear Assembly Replacement: 步骤 12 中的图像 1,1
    • The gear assembly will be covered in industrial lubricant, so wipe away an excess with a rag to reveal three screws.
  13. Ryobi RJ1861V Saw Gear Assembly Replacement: 步骤 13 中的图像 1,1
    • Remove three screws with a Torx bit and screw driver.
  14. Ryobi RJ1861V Saw Gear Assembly Replacement: 步骤 14 中的图像 1,1
    • Rotate the device 180 degrees and apply pressure to the gear assembly through the small hole, extra force may be needed in this step to break it loose.
  15. Ryobi RJ1861V Saw Gear Assembly Replacement: 步骤 15 中的图像 1,1
    • Once the gear assembly has broken free rotate the device again and lift it out of the gear housing.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 852
