跳转到主内容
Ryobi RJ1861V Motor Replacement
你所需要的
  1. Ryobi RJ1861V Motor Replacement, Saw Bar Assembly: 步骤 1 中的图像 1,1
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Motor Replacement: 步骤 2 中的图像 1,2 Ryobi RJ1861V Motor Replacement: 步骤 2 中的图像 2,2
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Motor Replacement: 步骤 3 中的图像 1,1
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Motor Replacement: 步骤 4 中的图像 1,1
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Motor Replacement: 步骤 5 中的图像 1,1
    • Remove the backside panel.
  6. Ryobi RJ1861V Motor Replacement: 步骤 6 中的图像 1,1
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
  7. Ryobi RJ1861V Motor Replacement: 步骤 7 中的图像 1,1
    • Lift the assembly bar up and out of the chassis.
  8. Ryobi RJ1861V Motor Replacement, Assembly Bar Bearing: 步骤 8 中的图像 1,1
    • Begin with the top of the device facing up.
  9. Ryobi RJ1861V Motor Replacement: 步骤 9 中的图像 1,1
    • Insert needle nose pliers to remove the retaining pin at the top of the bearing.
  10. Ryobi RJ1861V Motor Replacement: 步骤 10 中的图像 1,1
    • Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
  11. Ryobi RJ1861V Motor Replacement, Motor: 步骤 11 中的图像 1,1
    • The motor is divided into two sections, one attached to the gear case and one attached to the handle.
    • This arrow indicates the section attached to the gear case.
    • This arrow indicates the section attached to the handle.
  12. Ryobi RJ1861V Motor Replacement: 步骤 12 中的图像 1,3 Ryobi RJ1861V Motor Replacement: 步骤 12 中的图像 2,3 Ryobi RJ1861V Motor Replacement: 步骤 12 中的图像 3,3
    • Use a Torx T5 screwdriver to remove the four screws attaching the motor to the gear case.
  13. Ryobi RJ1861V Motor Replacement: 步骤 13 中的图像 1,1
    • Use a Torx T5 screwdriver to remove the two screws inside the motor housing of the handle.
  14. Ryobi RJ1861V Motor Replacement: 步骤 14 中的图像 1,2 Ryobi RJ1861V Motor Replacement: 步骤 14 中的图像 2,2
    • Remove the four screws on the back of the housing with a Torx T5 screwdriver.
    • Flip the housing over and pull the motor up and out of the housing.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 296
