跳转到主内容
Ryobi RJ1861V Motor Housing Replacement
你所需要的
  1. Ryobi RJ1861V Motor Housing Replacement, Trigger Assembly: 步骤 1 中的图像 1,1
    • Use a Torx T20 screwdriver to remove the nine 16.5 mm screws around the trigger assembly.
  2. Ryobi RJ1861V Motor Housing Replacement: 步骤 2 中的图像 1,2 Ryobi RJ1861V Motor Housing Replacement: 步骤 2 中的图像 2,2
    • Use a Torx T20 screwdriver to remove the two 16.5 mm screws near the trigger.
  3. Ryobi RJ1861V Motor Housing Replacement, Motor Housing: 步骤 3 中的图像 1,1
    • Use a Torx T20 bit or screwdriver to remove the six 19 mm screws securing the gear case cover.
  4. Ryobi RJ1861V Motor Housing Replacement: 步骤 4 中的图像 1,2 Ryobi RJ1861V Motor Housing Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #2 bit or screwdriver to remove the four 37 mm screws from the top and the bottom of the gear case.
    • Once these 4 screws are removed, you have access to the motor assembly.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 144
