跳转到主内容
Ryobi P501G Trigger Replacement
你所需要的
  1. Ryobi P501G Trigger Replacement, Shell: 步骤 1 中的图像 1,3 Ryobi P501G Trigger Replacement, Shell: 步骤 1 中的图像 2,3 Ryobi P501G Trigger Replacement, Shell: 步骤 1 中的图像 3,3
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
  2. Ryobi P501G Trigger Replacement: 步骤 2 中的图像 1,3 Ryobi P501G Trigger Replacement: 步骤 2 中的图像 2,3 Ryobi P501G Trigger Replacement: 步骤 2 中的图像 3,3
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
  3. Ryobi P501G Trigger Replacement, Trigger: 步骤 3 中的图像 1,1
    • After opening the shell, locate the black plastic trigger on the handle of the device.
  4. Ryobi P501G Trigger Replacement: 步骤 4 中的图像 1,1
    • Remove the black wiring and the trigger is free! Reposition it however you'd like or switch it out with a new one.
    • Make sure the trigger is snug and exactly where you want it. A dislodged trigger can be very dangerous in a power saw!
结论
Sophia Arias
于04/21/19注册
255 声望
创作了2篇指南
团队
Cal Poly, Team S1-G2, Maness Spring 2019 Cal Poly, Team S1-G2, Maness Spring 2019 的会员
CPSU-MANESS-S19S1G2
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 18
总计 1,686
