跳转到主内容
Ryobi P501G Shell Replacement
你所需要的
  1. Ryobi P501G Shell Replacement, Blade: 步骤 1 中的图像 1,1
    • Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
  2. Ryobi P501G Shell Replacement: 步骤 2 中的图像 1,2 Ryobi P501G Shell Replacement: 步骤 2 中的图像 2,2
    • Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
  3. Ryobi P501G Shell Replacement: 步骤 3 中的图像 1,3 Ryobi P501G Shell Replacement: 步骤 3 中的图像 2,3 Ryobi P501G Shell Replacement: 步骤 3 中的图像 3,3
    • Remove the four black screws holding the black bearing and remove the bearing itself.
  4. Ryobi P501G Shell Replacement: 步骤 4 中的图像 1,1
    • Once the black bearing is off, remove the transparent cover of the blade.
    • Once the cover is off, remove the blade.
    • Place the new blade with the flat notches lined up with the flat notches on the motor axle.
  5. Ryobi P501G Shell Replacement, Shell: 步骤 5 中的图像 1,3 Ryobi P501G Shell Replacement, Shell: 步骤 5 中的图像 2,3 Ryobi P501G Shell Replacement, Shell: 步骤 5 中的图像 3,3
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
  6. Ryobi P501G Shell Replacement: 步骤 6 中的图像 1,3 Ryobi P501G Shell Replacement: 步骤 6 中的图像 2,3 Ryobi P501G Shell Replacement: 步骤 6 中的图像 3,3
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
结论
Eeshan Mishra
于01/24/19注册
424 声望
创作了4篇指南
团队
Cal Poly, Team S1-G2, Maness Spring 2019 Cal Poly, Team S1-G2, Maness Spring 2019 的会员
CPSU-MANESS-S19S1G2
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 330
