跳转到主内容
Ryobi P501G Motor Replacement
你所需要的
  1. Ryobi P501G Motor Replacement, Motor: 步骤 1 中的图像 1,1
    • Locate the screws at the top face of the saw, on the green plastic surface covering.
  2. Ryobi P501G Motor Replacement: 步骤 2 中的图像 1,2 Ryobi P501G Motor Replacement: 步骤 2 中的图像 2,2
    • Locate the eight outer screws of the plastic green encasement. They are marked in red in the picture.
    • Using a T15 torx screwdriver, unscrew all the holes, taking care not to lose any!
  3. Ryobi P501G Motor Replacement: 步骤 3 中的图像 1,2 Ryobi P501G Motor Replacement: 步骤 3 中的图像 2,2
    • Open up the top side of the encasement to reveal the internal parts of the saw.
    • Locate the motor.
  4. Ryobi P501G Motor Replacement: 步骤 4 中的图像 1,2 Ryobi P501G Motor Replacement: 步骤 4 中的图像 2,2
    • Using the T15 torx screwdriver, unscrew all four of the screws to free the motor from the encasement.
  5. Ryobi P501G Motor Replacement: 步骤 5 中的图像 1,1
    • Remove the motor and replace with a new one if needed.
    • Be careful when handling the motor- it may be very dirty/greasy. You might want to wear gloves for this step!
结论
Sophia Arias
于04/21/19注册
255 声望
创作了2篇指南
团队
Cal Poly, Team S1-G2, Maness Spring 2019 Cal Poly, Team S1-G2, Maness Spring 2019 的会员
CPSU-MANESS-S19S1G2
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 41
总计 1,957
