跳转到主内容
Ryobi P501G Battery Replacement
  1. Ryobi P501G Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery at the base of the RYOBI P501G.
  2. Ryobi P501G Battery Replacement: 步骤 2 中的图像 1,3 Ryobi P501G Battery Replacement: 步骤 2 中的图像 2,3 Ryobi P501G Battery Replacement: 步骤 2 中的图像 3,3
    • Place your thumb and forefinger on opposite sides at the base of the RYOBI P501G, where the buttons to release the battery are located.
    • Click on the buttons to release the latches holding the battery in place and connected.
结论
Eeshan Mishra
于01/24/19注册
424 声望
创作了4篇指南
团队
Cal Poly, Team S1-G2, Maness Spring 2019 Cal Poly, Team S1-G2, Maness Spring 2019 的会员
CPSU-MANESS-S19S1G2
4 名成员
创作了7篇指南
一条评论
Replacement for Ryobi P501G Cordless Drill Battery
Type: Li-ion
Volt: 18V
Capacity: 6000mAh
Color: Black
Weight: 898g
Dimension: 135.70 x 76.00 x 107.30mm
This drill battery for Ryobi P501G is 100% compatible and will meet or exceeds original specification. This P501G replacement battery made by Amstron has been tested for safety and designed for high performance. go to view more at https://www.drillbattery.co.uk/batterysa...
Drillbatterycomau - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 512
