跳转到主内容
Ryobi P235 Magnetic Tray Replacement
你所需要的
  1. Ryobi P235 Magnetic Tray Replacement, Battery: 步骤 1 中的图像 1,2 Ryobi P235 Magnetic Tray Replacement, Battery: 步骤 1 中的图像 2,2
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Magnetic Tray Replacement: 步骤 2 中的图像 1,2 Ryobi P235 Magnetic Tray Replacement: 步骤 2 中的图像 2,2
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Magnetic Tray Replacement, Magnetic Tray: 步骤 3 中的图像 1,2 Ryobi P235 Magnetic Tray Replacement, Magnetic Tray: 步骤 3 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Magnetic Tray Replacement: 步骤 4 中的图像 1,2 Ryobi P235 Magnetic Tray Replacement: 步骤 4 中的图像 2,2
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Magnetic Tray Replacement: 步骤 5 中的图像 1,2 Ryobi P235 Magnetic Tray Replacement: 步骤 5 中的图像 2,2
    • Open the housing with the data label facing up.
  6. Ryobi P235 Magnetic Tray Replacement: 步骤 6 中的图像 1,1
    • Remove the magnetic tray from the device.
结论
Paul Sousa
于10/29/19注册
805 声望
创作了5篇指南
团队
UMass Dartmouth, Team S4-G2, Saloman Fall 2019 UMass Dartmouth, Team S4-G2, Saloman Fall 2019 的会员
UMASSD-SALOMAN-F19S4G2
3 名成员
创作了6篇指南
一条评论
Thanks for sharing, I was actually looking for these steps.
Mark Robert - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 304
