跳转到主内容
Ryobi P202 Trigger Assembly Replacement
你所需要的
  1. Ryobi P202 Trigger Assembly Replacement, Battery: 步骤 1 中的图像 1,3 Ryobi P202 Trigger Assembly Replacement, Battery: 步骤 1 中的图像 2,3 Ryobi P202 Trigger Assembly Replacement, Battery: 步骤 1 中的图像 3,3
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Trigger Assembly Replacement, Right Side Case: 步骤 2 中的图像 1,2 Ryobi P202 Trigger Assembly Replacement, Right Side Case: 步骤 2 中的图像 2,2
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Trigger Assembly Replacement: 步骤 3 中的图像 1,2 Ryobi P202 Trigger Assembly Replacement: 步骤 3 中的图像 2,2
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Ryobi P202 Trigger Assembly Replacement, Battery Contacts: 步骤 4 中的图像 1,2 Ryobi P202 Trigger Assembly Replacement, Battery Contacts: 步骤 4 中的图像 2,2
    • Grip the battery clip and pull straight up to remove the metal battery contacts.
    • You can now clean the metal battery contacts with isopropyl alcohol.
  5. Ryobi P202 Trigger Assembly Replacement, Trigger Assembly: 步骤 5 中的图像 1,2 Ryobi P202 Trigger Assembly Replacement, Trigger Assembly: 步骤 5 中的图像 2,2
    • Holding the direction select switch in place, grip both sides of the trigger assembly and lift it up and towards the base of the drill.
  6. Ryobi P202 Trigger Assembly Replacement: 步骤 6 中的图像 1,2 Ryobi P202 Trigger Assembly Replacement: 步骤 6 中的图像 2,2
    • To separate the trigger assembly from the motor, use a soldering iron to melt the solder and pull gently on the red and black wires from the trigger.
    • Heating the solder may melt the plastic packaging. Prior experience with soldering is required.
    • The trigger assembly is Part #: 270001392
结论
To reassemble your device, follow these instructions in reverse order. You will need solder to reattach the wires to the trigger assembly.
另外一个人完成了本指南。
Joseph Eckstein
于04/07/15注册
1,596 声望
创作了9篇指南
团队
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 的会员
CPSU-FORTE-S15S17G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 32
总计 4,936
