跳转到主内容
Ryobi P202 Gear Select Switch Replacement
你所需要的
  1. Ryobi P202 Gear Select Switch Replacement, Battery: 步骤 1 中的图像 1,3 Ryobi P202 Gear Select Switch Replacement, Battery: 步骤 1 中的图像 2,3 Ryobi P202 Gear Select Switch Replacement, Battery: 步骤 1 中的图像 3,3
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Gear Select Switch Replacement, Right Side Case: 步骤 2 中的图像 1,2 Ryobi P202 Gear Select Switch Replacement, Right Side Case: 步骤 2 中的图像 2,2
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Gear Select Switch Replacement: 步骤 3 中的图像 1,2 Ryobi P202 Gear Select Switch Replacement: 步骤 3 中的图像 2,2
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Ryobi P202 Gear Select Switch Replacement, Level Gauge: 步骤 4 中的图像 1,3 Ryobi P202 Gear Select Switch Replacement, Level Gauge: 步骤 4 中的图像 2,3 Ryobi P202 Gear Select Switch Replacement, Level Gauge: 步骤 4 中的图像 3,3
    • Rotate the Drill 180 degrees so that the top is facing you.
    • Lift the level gauge out from the top corner of the drill.
    • The level gauge is Part #: 3000909
  5. Ryobi P202 Gear Select Switch Replacement, Gear Select Switch: 步骤 5 中的图像 1,2 Ryobi P202 Gear Select Switch Replacement, Gear Select Switch: 步骤 5 中的图像 2,2
    • Lift the gear switch upwards from the top of the drill head.
    • The gear switch is Part #: 341098001
结论
Joseph Eckstein
于04/07/15注册
1,596 声望
创作了9篇指南
团队
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 的会员
CPSU-FORTE-S15S17G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 863
