跳转到主内容
Ryobi P202 Battery Replacement
  1. Ryobi P202 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Ryobi P202 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Ryobi P202 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
结论
另外一个人完成了本指南。
Joseph Eckstein
于04/07/15注册
1,596 声望
创作了9篇指南
团队
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 的会员
CPSU-FORTE-S15S17G6
4 名成员
创作了10篇指南
一条评论
Replacement Cordless Drill Battery for Ryobi P202
Type: Li-ion
Volt: 18V
Capacity: 2500mAh
Color: Black
Weight: 210g
Dimension: 135.70 x 76.00 x 98.30mm
Go to view more about this battery on http://www.drill-batteries.co.uk/shopbat...
Drillbatterycomau - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 25
总计 2,369
