跳转到主内容
Ryobi P202 Battery Contacts Replacement
你所需要的
  1. Ryobi P202 Battery Contacts Replacement, Battery: 步骤 1 中的图像 1,3 Ryobi P202 Battery Contacts Replacement, Battery: 步骤 1 中的图像 2,3 Ryobi P202 Battery Contacts Replacement, Battery: 步骤 1 中的图像 3,3
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Battery Contacts Replacement, Right Side Case: 步骤 2 中的图像 1,2 Ryobi P202 Battery Contacts Replacement, Right Side Case: 步骤 2 中的图像 2,2
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Battery Contacts Replacement: 步骤 3 中的图像 1,2 Ryobi P202 Battery Contacts Replacement: 步骤 3 中的图像 2,2
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Ryobi P202 Battery Contacts Replacement, Battery Contacts: 步骤 4 中的图像 1,2 Ryobi P202 Battery Contacts Replacement, Battery Contacts: 步骤 4 中的图像 2,2
    • Grip the battery clip and pull straight up to remove the metal battery contacts.
    • You can now clean the metal battery contacts with isopropyl alcohol.
结论
另外一个人完成了本指南。
Joseph Eckstein
于04/07/15注册
1,596 声望
创作了9篇指南
团队
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 的会员
CPSU-FORTE-S15S17G6
4 名成员
创作了10篇指南
4条评论
You don't really need to take apart the drill. You can clean the contacts with Qtips by reaching into cavity. Use rubbing alcohol and long Qtips. Also you can bend the contacts back to normal with a pair of needle nose plyers.
TheAarowsmith - 回复
Doe anyone know where I can buy new battery contacts as mine has snapped?
dsstirrup - 回复
Re snapped contacts, I’ve found this part no. but no supplier yet:
“Ryobi Contact Plate holder 300001044”
Jeremy Twiggs - 回复
Does anybody out there know where to find these as mine has snapped also, not ready to junk it out yet.
Kevin Kleckner - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 24
总计 4,040
