跳转到主内容
加入维修社区 - 创建账户
Ryobi CSB135L Motor Replacement
你所需要的
  1. Ryobi CSB135L Motor Replacement, Motor Housing: 步骤 1 中的图像 1,1
    • Remove the three M4.5 x 35mm screws that hold the motor housing to the blade housing using a Phillips screwdriver.
    • Although not required for motor housing removal, the two M4 x 16 mm Phillips head screws must be removed for access to the top of the motor.
  2. Ryobi CSB135L Motor Replacement: 步骤 2 中的图像 1,1
    • Remove the three M3.5 x 16 mm screws that hold on the laser cover using a Phillips screwdriver.
    • The wires that power the laser prevent the motor housing from coming off, so the laser must be removed.
  3. Ryobi CSB135L Motor Replacement: 步骤 3 中的图像 1,1
    • Pry the motor housing (green plastic) from the blade housing (gray plastic) using a metal spudger or any small pry bar.
  4. Ryobi CSB135L Motor Replacement: 步骤 4 中的图像 1,1
    • Fully remove the motor housing and blade cover to expose the motor and laser.
  5. Ryobi CSB135L Motor Replacement, Motor: 步骤 5 中的图像 1,1
    • Remove the two M4 x 16 mm screws using a Phillips screwdriver.
  6. Ryobi CSB135L Motor Replacement: 步骤 6 中的图像 1,1
    • Rotate the saw completely around to view the bottom of the motor as shown.
    • Remove the two 4.2 x 2.54 x 50 screws using a Phillips screwdriver.
  7. Ryobi CSB135L Motor Replacement: 步骤 7 中的图像 1,1
    • Pull out the motor assembly.
  8. Ryobi CSB135L Motor Replacement: 步骤 8 中的图像 1,1
    • Follow the wires from the motor to the wire cover and black box and undo the fastening of those wires to finish removing the motor from the saw.
结论
团队
UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023 的会员
UMASSD-RYCKEBUSCH-S23S7G3
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 231
