跳转到主内容
Ryobi CSB125 Motor Replacement
你所需要的
  1. Ryobi CSB125 Motor Replacement, Motor: 步骤 1 中的图像 1,1
    • Place the saw on a flat surface with the blade facing up.
    • Make sure that the saw is unplugged from any power source.
  2. Ryobi CSB125 Motor Replacement: 步骤 2 中的图像 1,2 Ryobi CSB125 Motor Replacement: 步骤 2 中的图像 2,2
    • Remove the bumper by using the T20 torx screwdriver to loosen the M5 x 20mm screw.
  3. Ryobi CSB125 Motor Replacement: 步骤 3 中的图像 1,2 Ryobi CSB125 Motor Replacement: 步骤 3 中的图像 2,2
    • Use the 7”/32 allen key to loosen the 5/16-18 x 9/16 in. blade screw.
  4. Ryobi CSB125 Motor Replacement: 步骤 4 中的图像 1,1
    • Remove the 5/16-18 x 9/16 in. blade screw, spring washer, the outer blade washer, the blade, and the inner blade washer.
  5. Ryobi CSB125 Motor Replacement: 步骤 5 中的图像 1,3 Ryobi CSB125 Motor Replacement: 步骤 5 中的图像 2,3 Ryobi CSB125 Motor Replacement: 步骤 5 中的图像 3,3
    • Use the #2 Phillip screwdriver to remove the four M4x16mm screws shown.
    • You will need to rotate the protective shell around in order to access them.
  6. Ryobi CSB125 Motor Replacement: 步骤 6 中的图像 1,1
    • Remove the lower blade guard support assembly from the rest of the saw.
  7. Ryobi CSB125 Motor Replacement: 步骤 7 中的图像 1,1
    • Flip the saw over and place the saw down on a flat surface with the motor facing up.
  8. Ryobi CSB125 Motor Replacement: 步骤 8 中的图像 1,1
    • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
  9. Ryobi CSB125 Motor Replacement: 步骤 9 中的图像 1,1
    • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
  10. Ryobi CSB125 Motor Replacement: 步骤 10 中的图像 1,2 Ryobi CSB125 Motor Replacement: 步骤 10 中的图像 2,2
    • Use the Phillips #2 screwdriver to remove the two M4x16mm screws holding down the end cover.
    • Pull off the end cover.
  11. Ryobi CSB125 Motor Replacement: 步骤 11 中的图像 1,1
    • Use the Phillips #2 screwdriver to remove the M45x35mm screw holding down the motor housing.
  12. Ryobi CSB125 Motor Replacement: 步骤 12 中的图像 1,1
    • Remove the motor housing for access to the internal motor components.
结论
3等其他人完成本指南。
Curtis Melo
于10/31/19注册
1,093 声望
创作了5篇指南
团队
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 UMass Dartmouth, Team S2-G1, Barthe Fall 2019 的会员
UMASSD-BARTHE-F19S2G1
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 616
