简介
When the gears of a hand mixer are warped or damaged this can cause them block, effectively rendering your mixer useless. Fortunately, it is easy to replace them, making your mixer function as new. If the gears are not damaged but just don’t run smoothly anymore, it’s also possible to clean and lubricate them.
你所需要的
Slightly loosen all four 2.54 cm Phillips #1 screws and remove them.
Remove the top casing.
即将完成!
结论
一条评论
Hey, do you have a print file or do you know a place where i can buy these gears? Would really like to repair my own mixer.
