跳转到主内容
Rubber Watch Battery Replacement
你所需要的
  1. Rubber Watch Battery Replacement, Battery: 步骤 1 中的图像 1,2 Rubber Watch Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Begin by placing the watch on its backside.
  2. Rubber Watch Battery Replacement: 步骤 2 中的图像 1,3 Rubber Watch Battery Replacement: 步骤 2 中的图像 2,3 Rubber Watch Battery Replacement: 步骤 2 中的图像 3,3
    • Gently pull the top of the watch's back until the cap detaches, in a peeling motion.
    • Pull out the white cap and green chip once it is free.
  3. Rubber Watch Battery Replacement: 步骤 3 中的图像 1,1
    • Carefully puncture the plastic casing next to the battery on top of the green chip with the X-Acto knife and stop.
    • Be careful not to insert the X-Acto knife too downward into the battery.
  4. Rubber Watch Battery Replacement: 步骤 4 中的图像 1,3 Rubber Watch Battery Replacement: 步骤 4 中的图像 2,3 Rubber Watch Battery Replacement: 步骤 4 中的图像 3,3
    • Flip the chip around to the front.
    • In a chiseling motion, make an incision on the front side above the battery to cut out a plastic casing.
    • Make sure to hold the knife away from the hands in a safe, stable grip.
    • Remove the cut plastic casing over the battery.
    • The plastic casing should come off like a cap.
  5. Rubber Watch Battery Replacement: 步骤 5 中的图像 1,1
    • Gently remove the battery with a spudger or a wooden coffee stick.
    • Using too much force may detach the tab holding the battery and break the watch.
    • Once free, remove the dead battery.
  6. Rubber Watch Battery Replacement: 步骤 6 中的图像 1,1
    • Insert the new battery.
    • Place the cut plastic cap casing over the chip and battery.
  7. Rubber Watch Battery Replacement: 步骤 7 中的图像 1,3 Rubber Watch Battery Replacement: 步骤 7 中的图像 2,3 Rubber Watch Battery Replacement: 步骤 7 中的图像 3,3
    • Place the white cap over the green chip.
    • Insert the white cap and green chip into the back of the watch with the spudger or wooden coffee stick.
    • Turn over the watch and check the power.
终点
Lee
于04/28/17注册
110 声望
撰写一个指南
团队
UC Davis, Team S2-G5, Cole Spring 2017 UC Davis, Team S2-G5, Cole Spring 2017 的会员
UCD-COLE-S17S2G5
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 781
