跳转到主内容
Royal Kludge Rk96 Keyboard Switch Replacement
你所需要的
  1. Royal Kludge Rk96 Keyboard Switch Replacement, Keyboard Switch: 步骤 1 中的图像 1,3 Royal Kludge Rk96 Keyboard Switch Replacement, Keyboard Switch: 步骤 1 中的图像 2,3 Royal Kludge Rk96 Keyboard Switch Replacement, Keyboard Switch: 步骤 1 中的图像 3,3
    • The Royal Kludge RK96 is a mechanical keyboard with fully adjustable features. Before starting the repairing process, verify that you have the appropriate replacement switch that fits the ones already on the keyboard.
  2. Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 2 中的图像 1,3 Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 2 中的图像 2,3 Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 2 中的图像 3,3
    • To prevent any electric mishaps, unplug your keyboard from the computer or any other device. Be sure that you securely unhook any USB or other connectivity ports.
    • To totally turn off your keyboard for a safe operation, use the toggle switch provided on the underside of the keyboard.
  3. Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 3 中的图像 1,3 Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 3 中的图像 2,3 Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 3 中的图像 3,3
    • Remove the keycap off the switch that you wish to replace carefully using a flat tool or keycap remover.
    • Place the tool beneath the keycap and carefully raise it.
    • To prevent losing the keycap, preserve it securely.
  4. Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 4 中的图像 1,2 Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 4 中的图像 2,2
    • With a gentle brush or compressed air, clear the area surrounding the switch after the keycap is off.
    • Be very cautious when cleaning to prevent harming other components.
  5. Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 5 中的图像 1,3 Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 5 中的图像 2,3 Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 5 中的图像 3,3
    • Grab the switch using the switch puller then cautiously raise it up to unclip and remove it.
  6. Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 6 中的图像 1,2 Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 6 中的图像 2,2
    • Align the new switch and carefully press it into the socket.
    • Remember to be mindful of the surrounding components of the keyboard.
  7. Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 7 中的图像 1,3 Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 7 中的图像 2,3 Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 7 中的图像 3,3
    • Plug in the keyboard to the PC.
    • Push the key that was changed gently to make sure it registers properly.
    • Use any text editor such as Microsoft Word or keyboard-testing-specific software.
  8. Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 8 中的图像 1,3 Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 8 中的图像 2,3 Royal Kludge Rk96 Keyboard Switch Replacement: 步骤 8 中的图像 3,3
    • Make sure the keycap is in line with the switch stem.
    • Depress the keycap firmly until it locks into position.
    • Make sure that the keycap is firmly positioned and fastened in line with all other keys.
终点
Xiangchi Huang
于01/31/23注册
157 声望
撰写一个指南
团队
York University, Team M-4, Allen Summer 2023 York University, Team M-4, Allen Summer 2023 的会员
YORK-ALLEN-SU23SMG4
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 30
总计 427
